Go Back   Home > Forums > Amplifiers > Class D
Old 4th April 2010, 01:19 AM   #1
tinitus is offline tinitus  Europe
Default Regulated supply, does it make sense ?
What do you think of regulated supply with classD amps ?
Is it worth the exstra effort and expense
Below is what I have in mind
Intended as TWO stereo amps, possibly bridged
Old 25th April 2010, 03:06 AM   #2
Generally class D drivers could be used in portable equipments which has a battery or, on big audio systems powered through mains. In any case, these types of systems would have a power management section which does supply regulation using buck converters.
Even if there was not much supply regulation, the class D could be made to sound great using negative feedback around the driver stage.
Old 25th April 2010, 06:39 AM   #3
Baldin is offline Baldin  Denmark
Baldin's Avatar
Send a message via MSN to Baldin
Hi Tinitus
Class-D has inherently a lower PSRR (Powre Supply Rejection Ratio), than class-AB, meaning that they are more sensitive to both hum (100Hz/120Hz) and other noise from the supply. The noise part can eaasily be the switching noise from one chanel to the other, resulting in beating. The noise will also be modulated and will show as distortion.
These problems are most visible in pure digital systems with no feedback.
See this on PurePath:
http://focus.ti.com/lit/an/slea049/slea049.pdf
But, with most designs today, there are enough feedback so this is not a problem, giving the amp a reasonably good PSRR
So to you question, it depends on the amp.
Using modules from e.g. Hypex will not have any problems with a non regulated supply.
Another thing is also that analog regulated PSUs only have good regulation at lower frequencies, and will probably not help anything for e.g. beating or switching introduced noise.
If you want regulation with Class-D, go for switch more power supplies.
These are inherently regulated, and well suited for class-d, and then you also get rid of the transformer
/Baldin
Visit www.sensibleaudio.dk or read latest news on Baldin's Blog
Old 25th April 2010, 08:15 AM   #4
AP2 is offline AP2  Italy
Hi, all
I agree that some amps have a good PSRR, I know two (Hypex and AudioPower DXA series) just because I've tested. there will be others on the market.
Apart from PSRR, psu switch is regulated and want high performance, there remains the problem of the current response time, this affects the sound amplifier.
(With traditional transformer, add a lot of capacitors and the tone is much rock).
Another problem is the introduction of THD and IMD at low frequency. apart from good PSRR.
MDI-Laboratories two years ago advanced research in this area (apart RIPS) is now testing a new PSU, based on two-channel analog modulator with independent sensing on the outputs.
This system emulates the stage of class AB fully featured digital amplifiers with poor PSRR also ensures 10.000uF per side (real 1500uF).
Certainly the research costs are too high but this is justified by the assignment of patents to other companies operating in different sectors from Audio.
Old 25th April 2010, 02:37 PM   #5
This is a simplified diagram of the concept that I presented before.
This new technique allows the use of small capacitors on the high voltage cell with the benefits of PFC
It also has the advantage of not introducing IMD / Noise on the device (fundamental reason is because when charge on transformer, it is disconnected from AC-line).
The core of the magic is the time base.
unfortunately can not be achieved with traditional chips and then this increased development costs, but ... this is a problem now passed.
This concept was derived from the RIPS, very similar, and was replaced with the second channel analog to better adapt to digital amplifiers, the result on amplifier is incredible ...
Old 25th April 2010, 04:58 PM   #6
Can you buy one of these supplies? If so,where?
Old 25th April 2010, 05:24 PM   #7
this is in production for audiopower.it ,I think is ready
in mid-May.
dimension (156x90x30mm) version 750w max.
Old 25th April 2010, 05:25 PM   #8
Will it be available in the UK? Do you know the price?
Old 25th April 2010, 05:33 PM   #9
I do not know, but I think the price will be competitive for the product launch.
All models of this new technology can accept 100-130/200-260VAC.
Old 25th April 2010, 07:06 PM   #10
Is this the company?
Audio Power Industries
Does this power supply make any sense to you? Cassiel Tubes / Valves 14 17th June 2009 05:18 PM
Using resistor in sense line to increase range of regulated supplY? VictoriaGuy Power Supplies 3 12th December 2008 07:54 PM
Linear voltage regulator: how to make good use of "sense" and "ground sense"? NeoY2k Analog Line Level 7 6th September 2008 11:35 PM
Does this make sense ? 00940 Solid State 7 27th March 2004 09:29 PM
Does this make sense? Illusus Chip Amps 11 25th September 2003 01:59 PM
Page generated in 0.24308 seconds (42.67% PHP - 57.33% MySQL) with 11 queries
