New TK2050 board
New TK2050 board
Old 4th September 2010, 01:24 PM   #701
ptiJean is offline ptiJean  France
It's working !
All for me, apologies : my input RCA ground have problems.
Just disconnect your ground and you'll hear what I have heard.
Thank you all, especially Steinar !
Old 4th September 2010, 02:07 PM   #702
alkasar is offline alkasar  France
Old 6th September 2010, 11:13 AM   #703
Some listening feedback :
First tried v2 PCB alone, no preamp, adjusting volume with it's pot.
It sounded wonderfull, high, a lot of air, with clean background, this is very addictive.
But it lacked a little bit of dynamic and "timbres" (dunno how to say it in english).
I then added my Cochet tube preamp, with 2 Cifte 5 stars triple mica preamp, and it was better.
Better dynamic and warmth, same background and overhall signature
I have tried a lot of pots last year on my preamp and have always found it is critical and needs very high-end attention.
I fear that the original small blue pot of the v2 PCB (what's the exact reference ?) slows and darkens the sound a little bit.
I'll have to try other pots like ALPS blue or black beauty, or Digikey PEC.
But this board is a masterpiece and outperforms my EL34 push-pull in almost everything else ! I fear that my tube amp will have to stop service
This classe-D has huge and very good bass with control, details. It has extremely good low-highs, cimbals explode in my living-room like never before.
All of this is really enjoyable
Yannick
Old 6th September 2010, 01:23 PM   #704
kickngas is offline kickngas  United States
Nice review. What speakers are you driving, their efficiency, and how loud do they get. I have a TA 2020 and want more volume.
http://thsev.blogspot.com/
Old 6th September 2010, 01:29 PM   #705
Hi kickngas,
I'm using Tannoy D500, 91 dB/W/m, and was listening to normal volume, not extremely loud.
They have one 8" polypro coaxial HP and one 8" woofer.
Old 6th September 2010, 01:42 PM   #706
I have a TA2020 (Arjen Helder). It plays very well, but limited to 15/20W. Hifimediy TK2050 board delivers much more power, and to my ears, an even better sound than ta2020.
I have 86db 2-way diy loudspeakers (zaph sr71). it plays loud enough
Old 6th September 2010, 01:57 PM   #707
I would love to see a review of the HiFImeDIY 2050 against the Helder dual mono 2050. Wonder if there is any significant difference between the two. I will most likely go with the HiFimeDIY board since I can not fit the Helder boards in my existing chassis.
Old 6th September 2010, 01:57 PM   #708
Originally Posted by alkasar View Post
Does anyone have THD data/measures for sta505 and sta517B ? particularly thd vs output power at various frequencies. The datasheets are not very informative. Thanks.
nobody ? a well kept secret ?
Old 6th September 2010, 03:10 PM   #709
Bernie7 is offline Bernie7  Singapore
Yannick
Use LDRs as your volume control and you may never want to use another pot, TVC, AVC, DVC, SA, or preamp again, tube or otherwise
Old 7th September 2010, 03:43 AM   #710
transamz2000 is offline transamz2000  United States
Default cap size
would upping the 4700uf cap to 18000uf or 22000uf have in negative affects on the power supply of the v.2 using meanwell s350-27
New TK2050 boardHide this!Advertise here!
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 31st May 2011 12:06 AM
Any input on the new Dayton TK2050? finnbow Class D 10 3rd May 2011 12:37 AM
Parallled tk2050/st505 paolo66 Class D 1 24th November 2009 06:10 PM
New Sure electronics TK2050 T-amp xaudiox Class D 2 8th May 2009 08:50 AM
Tripath TK2050 Eccu Digital Source 0 19th April 2002 12:06 PM
