New TK2050 board
New TK2050 board
Old 16th August 2010, 05:49 PM   #601
kingnubian is offline kingnubian  Canada
Originally Posted by zog666 View Post
OK, implemented this.. of course hard to quantify but I think the amp can pour out a lot more definate bass now!
But then I know I've increased the capacitance from 4700uF to 24700uF.
Here is a picture of my fairly basic enclosure setup (electronics store instrument enclosure):
its the enclosure (and extra capacitors + transformer) repurposed from my dead YuanJing module
All fits very nicely. I'm using a bamboo chopstick stuck on with hotglue as the rail to attach the extra caps to.
Now I'm really enjoying the amp.. it's very quiet, very clear, and can put out quite heavy bass with my econowave speakers.
good stuff!
Exactly the setup I'm after. Pictures are worth a thousand words.
Old 16th August 2010, 09:53 PM   #602
kc7wdg is offline kc7wdg  United States
Originally Posted by TCx View Post
Hi all, if I wanted to use TK2050 v.1.1b module (without pot) with external pot, what value would you recommend? Can I use 10kOhm? Or is higher value (like 50kOhm) better? Thanks.
I to would like to know this.
Old 17th August 2010, 12:13 PM   #603
hifimediy is offline hifimediy  China
I think 10k~100k ohm is ok for general purpose. If the output impedance of your source is large, choosing a 50k or 100k ohm pot will be better.
We use 50k ohm type A now.
Old 17th August 2010, 12:36 PM   #604
Default new post
Originally Posted by SoldierAnt76 View Post
A new topic might be preferable, since this DDX board you're developing is a substantially different product and it isn't a "TK2050 board," as the name implies. You'd probably get more attention and feedback from a new discussion anyway, since these conversations can get unwieldy after the first fifty pages or so.
I post a new topic at last: DDX AMP.
I will post information of new progress there later.
Old 17th August 2010, 02:50 PM   #605
udailey is offline udailey  United States
Passive Aggressive
New TK2050 board
Can two T3 be used for one subwoofer?
Can power supply board split into two so that I can have two monoblocks in two enclosures?
Uriah
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 17th August 2010, 04:35 PM   #606
Uriah
T3 does not support parallel use. There will be a new power supply board for one channel.
Old 17th August 2010, 04:45 PM   #607
Steidl Guitars is offline Steidl Guitars  United States
Default Sizing Toroid for v2 board
Originally Posted by kingnubian View Post
I'll probably initially going with a toroidal transformer (Antek - AN-4228) for power.
I too am new at all this (so take this with a grain of salt!) and would like to use a toroidal transformer with the V2 board.
The one you linked to makes 28 v (which I assume is AC, yah?) which seems higher than what recommended, which is AC 16 - 22 v according to the website.
So wouldn't something like this be better, as it makes 20 v?:
Antek - AN-3220
Someone who actually knows what they're doing willing to set is straight?
Old 18th August 2010, 01:32 AM   #608
Antek - AN-3220
You are correct. I looked over the specs & confirmed what you are saying.
Btw, I also have another kit, ClassDAudio's SDS-254, coming in & would love someone who has done a serious audio quality comparison to chime in.
I am most excited about working with the Hifimediy kit though. I haven't even built my first kit yet & I'm already hooked.
Old 18th August 2010, 05:30 AM   #609
TheDealer is offline TheDealer  Germany
I think it isnīt done with just a toroidal transformer. I am not sure but the voltage regulation is an area for itselves and in your case I would recommend an industrial smps from meanwell, cosel, lambda etc.
Old 18th August 2010, 10:02 AM   #610
alkasar is offline alkasar  France
Antek - AN-3220
As TheDealer said, I would also recomend the meanwell smps instead of a transformer.
I was used to toroidal + linear supplies with other classAB amps. I must say that I am really impressed by meanwell 350W smps + amt2050v2 board.
If you really want to use a transformer, the recomended range for AC transformer for this board is 16-22V.
20V is perfect. It will provide 20 * 1,414 - 1,2 = 27V at the amp level (Vcc).
The link you give for the Antek has dual output. You only need one output for this board. You can save money, space and weight .
With a transformer, I recomend to increase the size of the power cap, for example as zog666 did (see previous page). Not needed if a meanwell smps is used.
New TK2050 boardHide this!Advertise here!
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 31st May 2011 12:06 AM
Any input on the new Dayton TK2050? finnbow Class D 10 3rd May 2011 12:37 AM
Parallled tk2050/st505 paolo66 Class D 1 24th November 2009 06:10 PM
New Sure electronics TK2050 T-amp xaudiox Class D 2 8th May 2009 08:50 AM
Tripath TK2050 Eccu Digital Source 0 19th April 2002 12:06 PM
Copyright ©1999-2017 diyAudio
