New TK2050 board
New TK2050 board
Old 24th April 2010, 05:14 PM   #21
sendler is offline sendler  United States
Default Try it
Originally Posted by Nick122147 View Post
Thanks sendler! So you're saying that the present solution is prefarable to adding an (higher quality) stepped pot which is wired on?
I haven't listened to pots in along time. It's hard to say. It would be easy for you to try a stepped attenuator to find out. I'm not crazy about the current crop of series attenuators for technical reasons though. I haven't tried one but it seems that you are adding a lot of solder joints to the signal path. You colud actually just measure your pot at a reference listening level and then duplicate the attenuation with different values of resistors in it's place on another amp in order to compare at that fixed level.
Scott
Old 24th April 2010, 05:33 PM   #22
teamacc is offline teamacc  Netherlands
How about these?
* 2 pcs * of DACT Type 21 Stepped Attenuator 100K 2A3 - eBay, Integrated Amplifiers, Amplifiers, Home Audio, Electronics. (Eindtijd 18-mei-10 16:28:03 CEST)
No solder joints, 1% SMD resistors.
Only thing it might be carbon resistors though... :S
Got two of those here
Old 24th April 2010, 05:56 PM   #23
Default Series attenuators
Originally Posted by teamacc View Post
How about these?
Those are the series style that have become common. The signal passes through every resistor, one at a time, on it's way through. 100k is very high but you never know what something will sound like until you listen. Sound often does not follow theory. There are many trade offs.
Scott
Old 24th April 2010, 06:02 PM   #24
a.wayne is offline a.wayne  United States
Sin Bin
Hello Scott,
Which class- d kit would you recommend as the best currently available ?...
Old 24th April 2010, 06:03 PM   #25
Nick122147 is offline Nick122147  China
Originally Posted by sendler View Post
A tube pre might as well bypass the pot.
What would be the input impedance if I bypass the pot?
Old 24th April 2010, 07:25 PM   #26
Default Impedance
It would tend to be set by the gain setting divider in front of the TC2000 which forms a virtual ground in the center tap depending on what values you chose for the series resistor so probably 22k but this is virtual ground so I am not sure that it actually might measure higher. My dac chip seems to prefer an additional terminating resistor of 22k to ground on the input. You can go crazy tweaking a circuit. Everything sounds different including many things that engineer types will tell you that you can not hear. At some point you have to stop and just listen to music.
Scott
Old 24th April 2010, 07:33 PM   #27
Default Best kits
Originally Posted by a.wayne View Post
Hello Scott,
I have only tried one class D amp and it turned out to kill the sonics of my AB amps. A TK2050 seems hard to beat for the price. I would stick with that over a 2020,2022,2024. The truepath 3020 also gets great reviews but costs more. I need 8 channels at least, maybe more if I use DVC woofers so price is somewhat under consideration.
Scott
Old 24th April 2010, 08:09 PM   #28
Sin Bin
Are you specifically recommending the TK 2050 kit listed here ?
Old 24th April 2010, 10:51 PM   #29
Default Nice
His amp looks quite nice with volume and speaker protection already on the board but I don't think he has any more right now. Also, I have found that the output coil is crucial and I would mod it with the Wurth WE-PD XXL coils no higher than 6uH.
Scott
Old 25th April 2010, 04:03 PM   #30
I'm thinking of trying battery power. Would two batteries like this be ok? Can I charge them also in series with a 24V charger?
12V7AHƿ 12V7AH άʽǦ-Ա
translated specs:
Battery 12V7.0Ah/20hr
Rated Voltage: 12V
Rated Capacity (20hr): 7Ah
Dimensions: Length: 151mm Width: 66mm high: 96mm Total height: 102mm
Reference Weight: about 2.8Kg
Actual capacity of different discharge rate
20 hours rate: 7Ah
10-hour rate: 6.5Ah
5 hour rate: 5.9Ah
1 hour rate: 4.2Ah
15-minute rate: 2.9Ah
The relationship between volume and temperature (20 hour rate)
40 ℃ (104 ℉): 103%
25 ℃ (77 ℉): 100%
0 ℃ (32 ℉): 86%
-15 ℃ (5 ℉): 65%
At 25 ℃ (77 ℉) resistance when fully charged: about 22mΩ
Charging method (constant voltage)
Cycle: the maximum charge current of 1.75A
Charging voltage 14.5-15.0V/12V77 ℉ (25 ℃)
Charge temperature compensation voltage-24mV / ℃
Float: Maximum charging current 1.75A
Charging voltage 13.6-13.8V/12V77 ℉ (25 ℃)
Charge temperature compensation voltage-18mV / ℃
Apply to electronic scales, emergency lights, children's toy cars, lawn, parking locks, power systems, access control systems, uninterruptible power supplies, etc.
New TK2050 boardHide this!Advertise here!
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 30th May 2011 11:06 PM
Any input on the new Dayton TK2050? finnbow Class D 10 2nd May 2011 11:37 PM
Parallled tk2050/st505 paolo66 Class D 1 24th November 2009 05:10 PM
New Sure electronics TK2050 T-amp xaudiox Class D 2 8th May 2009 07:50 AM
Tripath TK2050 Eccu Digital Source 0 19th April 2002 11:06 AM
Copyright ©1999-2017 diyAudio
