New TK2050 board
New TK2050 board
Old 14th June 2010, 03:47 PM   #211
sendler is offline sendler  United States
Default Rfbc?
What value for RFBC/RFBB is used on this board? Is the input gain set to unity, RI=RF? Was the schematic posted earlier in the thread? Is good quality heatsink paste used or rubber adhesive used? It seems that the TP2050 output chips are barely able to get enough heat transferred through the die to the heatsink as the early Sure amps with passive heatsink and rubber adhesive were prone to burn up at voltages higher than 24v.
Scott
Old 14th June 2010, 04:18 PM   #212
Nick122147 is offline Nick122147  China
Originally Posted by jean-paul View Post
I wish I had read previous posts as my amp also decided to smell. It was on 33V with 8 Ohm test resistors. I kept it on voltage for a while to be sure it works OK.
I'm sorry to hear that. I had emailed everybody, but just realized you was not on my list because you were the first one buying.
here is the schematic http://steinar.eu/tk2050/AMT2050%20TK2050.pdf
My understanding is that the chip should power off if it gets to warm.
Old 14th June 2010, 05:47 PM   #213
Default Protection
The spec sheet for the TK2050 mentions an over temp protection circuit built in but it doesn't work at all in practice for some reason as hundreds of 4X100 users can attest to. Those amps are prone to burn up two of the chips due to a slight warpage of the circuit board which results in a poor fit between two of the chips and the heatsink. Sure was eventually forced to disable two of the outputs and sell the boards as two channel amps because of this. So it appears that the heatsink to chip interface and quality of paste is critical. Even so, it seems to me that the circuit temp can actually momentarily spike much higher than the heatsink temp causing failures on an otherwise 65C heatsink. You may want to do some measured thermal stress testing by fixing a temp probe to the heatsink, then gradually covering the heatsink with a towel to find the failure behavior at different supply voltages and choose the highest voltage that still won't fail with the heatsink completely covered. 31v may still be a bit too high of a risk for that heat sink once people start putting the modules into a case.
Scott
Old 14th June 2010, 07:18 PM   #214
glt is offline glt  United States
Thats an idea for later. It's not possible on this board. And I'm not sure how big demand it would be for this feature.
Is it just a matter of the relays? the sureelectronics board are advertised to work from 10V up. I suppose I can bypass the relays if I choose to use only 12V. Thanks for all your work and info.
www.hifiduino.wordpress.com
Old 14th June 2010, 08:32 PM   #215
bambadoo is online now bambadoo  Norway
Just bought 2 pcs from your ebay site :-)
Greetings from Norway
Sincerely
Old 15th June 2010, 05:05 AM   #216
marchel is offline marchel
Hi, Where can I buy this amp. Can you give me link to the ebay site?
Old 15th June 2010, 05:29 AM   #217
cragthehak is offline cragthehak  Canada
I'm about to order one of these boards. From the sounds of things, would a smaller supply like this one at 24v 6A work better for this?
145W 24V DC 6A Regulated Switching Power Supply [K018] on eBay.ca (item 200475424389 end time 22-Jun-10 03:24:46 EDT)
Marchel, look for post #163 in this thread for the ebay link.
Old 15th June 2010, 06:04 AM   #218
Thanks.
Old 15th June 2010, 07:19 AM   #219
cirkittboy is offline cirkittboy  Australia
That would work ok but the 350watt Meanwell SMPS turned down to31v out would be better,well more powerfull anyway.
Old 15th June 2010, 10:52 AM   #220
Default S-350-24
Unless size is an issue, I would spend a little more and get the S-350-24 or 27v MeanWell power supply.
Scott
New TK2050 boardHide this!Advertise here!
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 30th May 2011 11:06 PM
Any input on the new Dayton TK2050? finnbow Class D 10 2nd May 2011 11:37 PM
Parallled tk2050/st505 paolo66 Class D 1 24th November 2009 05:10 PM
New Sure electronics TK2050 T-amp xaudiox Class D 2 8th May 2009 07:50 AM
Tripath TK2050 Eccu Digital Source 0 19th April 2002 11:06 AM
Copyright ©1999-2017 diyAudio
