New TK2050 board New TK2050 board - Page 217 - diyAudio
New TK2050 board
New TK2050 board
Old 8th October 2012, 09:25 PM   #2161
Trebla is offline Trebla  United Kingdom
Originally Posted by zanlation View Post
Can I just check the order of RCA parts. from external to internal - PLUG -> plastic washer -> chassis -> plastic plug -> ground washer/ring -> nut -> positive wire soldered to end.
Yes, that's right.
Old 9th October 2012, 12:08 AM   #2162
midyim is offline midyim  Australia
Default Hot! Hot! Hot!
I am seeing heatsink temperature of 30C over ambient...with local temps approaching 30C. Need suggestions to extend the heatsink {or do I have a problem with my T2{M}?
Using 24Vac supply giving 35.5Vdc {appears the AC is higher then rated}
No input, no load, DC offset=0V
Thks...eng hoe
Old 20th October 2012, 03:53 AM   #2163
zanlation is offline zanlation  Australia
I conducted some experiments to try and isolate my noise problem. I rewired the input RCA plugs, including giving them a common ground, and double checked other wiring.
The 2ch T4 when powered up gives a high pitch sound from the amp itself (and when the speakers are connected too). The red LED comes on, but no sign of the relay green LED lighting up and no clicking sound.
The 1ch T4 (with grounded left channel) doesn't make a sound, the red LED comes on OK, but the relay green LED flashes on and off, with clicking sound, but eventually fails.
I rewired from SMPS800RE to each amp with all three wires (Live, Ground, Neutral). I noticed that these T4 boards have a different layout to my previous one (that also have mundorf caps). The SMPS800RE has been set to output 34V.
Can anyone point me to some potential problems?
Old 20th October 2012, 10:01 AM   #2164
alkasar is offline alkasar  France
T4 needs single voltage dc power supply or dual voltage transformer.
SMPS800RE is a symetrical voltage power supply (+/- voltage). How exactly have you wired the power supply to the amp ?
34Vdc is probably too low to trigger the relay. Specs says min voltage is 36Vdc.
Also, it sometimes helps to reference smps 0V output to earth. Either through a wire or a 10 to 100ohm resistor. This eliminates noise in some circumstances.
Old 20th October 2012, 12:03 PM   #2165
Hmmm, looks like I made a mistake on the voltage. So, 34-0-34 is AC and I needed 36V+ for DC--- which I have on my other amp in DC mode. So, can I manually change the voltage on the SMPS800RE?
Old 20th October 2012, 01:19 PM   #2166
you can adjust smps800RE output voltage a little, 5% or so. There is a small potentiometer on board to do that, using a screwdriver.
However, the smps output is dc, not ac, and should be wired to T4 as a dc supply, like you did with 500RS (S stands for single) on your other amp.
Althought not recomended, you can try using only the V+ output and leave the V- unconnected. It's a pity as you lose hal of the smps power.
SMPS800RE is not suited for T4.
Old 20th October 2012, 10:19 PM   #2167
Thanks for the help, this project is taking me a lot longer than my previous amp and my knowledge is being stretched again, which is good
Which single SMPS would you recommend to run the two T4s?
Old 20th October 2012, 11:11 PM   #2168
Is the noise issue related to lower than min required voltage?
Old 22nd October 2012, 09:13 AM   #2169
don't think so. reference smps 0V to earth has a better chance to eliminate noise.
To recomend a power supply, need to know how you will use this amp.
why not try with the 500RS of your other T4 stereo amp ?
Old 22nd October 2012, 07:26 PM   #2170
TheDealer is offline TheDealer  Germany
maybe a bit offtopic but I hope you can give me answer. As here the RCA issue was discussed lastly I was wondering how channel separation works when R and L share same GND on for example T1 board . Isn't R and L channel connected together in this case ? I measured also a T2 board. Indeed R and L are connected together through the GND Thanks in advance for a tip
New TK2050 boardHide this!Advertise here!
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 30th May 2011 11:06 PM
Any input on the new Dayton TK2050? finnbow Class D 10 2nd May 2011 11:37 PM
Parallled tk2050/st505 paolo66 Class D 1 24th November 2009 05:10 PM
New Sure electronics TK2050 T-amp xaudiox Class D 2 8th May 2009 07:50 AM
Tripath TK2050 Eccu Digital Source 0 19th April 2002 11:06 AM
Copyright ©1999-2017 diyAudio
