New TK2050 board
New TK2050 board
Old 13th August 2012, 02:22 PM   #2141
hifimediy is offline hifimediy  China
Originally Posted by whelibob View Post
Its getting quite expensive to use my ghettoblaster if i have to change the amp once a month. So it would be nice to know what have i done wrong.
Here is the burned chip:
http://i78.photobucket.com/albums/j1...811_185319.jpg
All other components seem to be ok.
Hi, I'm sorry for that. There is some unknown situation when increase the gain. Could you see any chips burned? If the chips not burned, you can try to replay the bead with a short wire/ jumper.
And by the way, if you can, I think it's better idea to add a pre-amp when you find the output is not large enough.
Old 13th August 2012, 02:31 PM   #2142
Originally Posted by zanlation View Post
I came across while surfing the net, as your do on a Sunday afternoon, and discovered bass shakers. This got my mind thinking about using the spare channel on my T4 amplifier to output to a bass shaker. So, two channels would be LR and the other two would be centre and bass shaker. Here's the catch... my centre speaker is 8ohms and the bass shaker is 4ohms. I only need 50W for the bass shaker so power isn't an issue, but having two different ohms speakers might. Thoughts anyone?
I think T4 is no problem for the center speaker, but if you want to drive 4ohm bass shaker, you'd better use lower supply voltage for safe. or if you can make sure the input signal is not too high for bass, it will be ok too. The T4 use sta516B so you can get 100W max to 4ohm, must not be more.
Old 19th August 2012, 09:43 PM   #2143
b4rr3l is offline b4rr3l
T2 @ Special Edition TC2000 + TP2050
Old 17th September 2012, 05:59 PM   #2144
TheDealer is offline TheDealer  Germany
Hi folks or Hifimediy,
I dummy did not care this time for the right diode direction. The red power diode of my T2 was extended to the power switch but sadly interchanged ...
After main powering smps made a buzzing noise and no lights went ON. Smps seems to be O.K. but after soldered into right position the amp still not works. Is the board damaged or what else can I do ... ?? Thanks.
Old 18th September 2012, 02:31 PM   #2145
Hi, is "the red diode" means LED? I don't quite understand, sorry.
Old 18th September 2012, 05:02 PM   #2146
yes LED , but I have news. I tried another new T2 and this time I took care. The second T2 worked but after mounting into the chassis and connecting speaker-outs it made same problem like first T2. A buzzing noise while red LED is ON. I suspected the speaker-outs and disconnected them from amp. Indeed both amps work with a klick and speaker-relay LED (yellow) is ON. When connected the binding posts of the chassis to the T2 the noise again appears while the speaker-relay LED is OFF and red power LED is ON. It seems that I did not make a mistake with first LED. Both boards obviously work with disconnected speaker outs ...?!! I sent also an eMail to you. Thanks for your help.
Old 20th September 2012, 12:06 PM   #2147
... anybody any suggestions, supposes ??
I made another thing. I have disconnected the speaker outs and switched the T2 ON. Power LED and speaker LED went ON with a klick noise. Fine. Then I touched one speakercable with + of left channel and instantly a small flash, klick and amp shuts down. Then again switched the T2 ON. This time I touched - of left channel. Again same thing appeared. Klick, lights OFF and amp shuts down.
Yubing it seems that both amps work without speakerconnections. If you remember I had same issue in the past with a T1. You said to me that my smps probably makes a problem.
The smps is not the problem because this time I checked up with 24 V battery and same thing happened again. Please PM or eMail. Thanks ...
Old 20th September 2012, 01:36 PM   #2148
Hi, I don't quite understand why it's fail when installed into the chassis. But I'm thinking about some possible reason. The first is that the input cable is not good connection, and then pls check the output cable(from amp to connectors), to see if any output terminal is Grounded. I suggest use a multimeter to check these upon carefully before power on, any mistake may kill the amplifier. There is also another possibility, the bottom of board touched the chassis (metal). And I also need a photo to check more if you can give
Old 20th September 2012, 01:37 PM   #2149
DarpMalone is offline DarpMalone  Canada
DarpMalone's Avatar
Hi Dealer... Have you checked for continuity between the binding posts and the enclosure? Are you sure you they're not shorted?
Old 20th September 2012, 02:54 PM   #2150
von Ah is offline von Ah  United States
von Ah's Avatar
Plus one to that. DarpMalone and tamphist were right on with this when I had similar problems.
http://www.diyaudio.com/forums/class...ml#post2411682
http://www.diyaudio.com/forums/class...ml#post2423475
Good luck!
New TK2050 boardHide this!Advertise here!
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 30th May 2011 11:06 PM
Any input on the new Dayton TK2050? finnbow Class D 10 2nd May 2011 11:37 PM
Parallled tk2050/st505 paolo66 Class D 1 24th November 2009 05:10 PM
New Sure electronics TK2050 T-amp xaudiox Class D 2 8th May 2009 07:50 AM
Tripath TK2050 Eccu Digital Source 0 19th April 2002 11:06 AM
