New TK2050 board
New TK2050 board
Old 6th May 2012, 07:59 AM   #2091
hifimediy is offline hifimediy  China
Originally Posted by whelibob View Post
Hey, is there any chance I could save my Hifimediy AMT 2050 V1.2?
I desoldered R1 and R3 inpu tresistors(?) to increase the gain. Yes, I should have read hifimediys post which told me to change R2 and R3 and not touch R1 at all. The problem is now that the thin connection under the surface of the PCB going from R3 towards TC2000 is cut and with my solder skills i am not able to solder it back on. The original value of all R1, R2, R3 and R5 are 22k ohm and I liked the gain value when my resistors values were R1 22k, R2 56k, R3 56k, R5 22k.
If i remember correct those resistor pairs(R1,R3 and R2,R5) were in parallel/series. So my question is is it possible to let R3 be unconnected and change R1 to a value that matches with R2 being 56k and R5 22k?
Another question, does it damage the amplifier when my R3 was unconnected and the amp was on. The channel voltage showed 29.4V :/
This was another lesson for me not do things in a hurry. Always something goes wrong.
Hi, I don't think un-connect R3 is ok, but your amp may not be damaged if just R3 disconnected. You can see from sch that R3 is a feedback resistor so it's quite normal to output high voltage when you open the feedback loop.
I will post a picture here below, may help you to repair.
Old 6th May 2012, 08:17 PM   #2092
whelibob is offline whelibob  Finland
Ok I'll have to try to repair it. Luckily i have two of those amps so got the other soldered properly. But what i noticed that, there is quite alot more "hiss" compared to the V2.0 version, is this normal? I swapped R3 and R2 to 56k ohm resistors. In my V2.0-board the equivalent resistors were 47k, if that affects?
Old 6th May 2012, 08:56 PM   #2093
My powersource is a 36V lithium ion if that matters. It should produce noiceless power iv'e understood correct.
Old 7th May 2012, 02:12 PM   #2094
I think it's not normal. You can try again when you fixed it. And try to check the input connector/cable when you still have such problem.
Old 10th May 2012, 12:36 AM   #2095
zanlation is offline zanlation  Australia
I am looking into building my second amplifier to drive my LR front and centre speakers in my home threater system. I built a HiFiMediy T4 a few months ago and was thinking about using the same amplifier with the SMPS500R in the new build. This leads to my question: Can you drive 2 T4s from 1 SMPS500R?
Old 7th June 2012, 08:12 AM   #2096
greententacle is offline greententacle  Finland
I ordered a T2 a while back, and it's been waiting in its shipping box since; I also got a T1-M which is wonderful at keeping me busy
Now that I hooked the T2 up to a 24V (2x12V SLA) battery (25.4V measured voltage) and two 4 ohm car speakers, there are several problems:
  • The output is very noisy, worst at zero volume
  • The output is very distorted
  • There seem to be PWM artifacts present (certain "buzziness" in the sound)
As for other things, the amp seems to be functioning normally. Output DC is 0.02V 0.03V. Both red and green leds are on.
I notified hifimediy of the problem by replying to my invoice, but haven't yet heard anything from them.
Does anyone have any ideas as to what could be wrong?
Old 7th June 2012, 06:17 PM   #2097
eladmi is offline eladmi  Germany
Hi there
I would like to use ane iPhone as audio source for the t2. As far as I know there will be a problem with the input sensitivity on the t2. Could anyone please advice me which resistors should be swapped? What would be the rating of the new resistors? Does anyone know the output sensiticvity of an iphone? Lots of qustions ;-)
Thanks in advance
Cheers
Old 11th June 2012, 10:44 AM   #2098
Electrix666 is offline Electrix666
After some looking for a TK2050 amplifier I really don't know which one to buy.
Which amplifier and PSU is recommended for speakers with the following specs?
Element: 1" SuperAudio-treble, 2 x 3,5-" base
Impedance: 6 Ohm
Freq.range: 50-32000 Hz, 100-24000 Hz (+-6 dB), 150-22000 Hz (+-3 dB)
Delningsfrekvens: 4200 Hz
Sensitivity: 88 db (-+3 dB)
Max Power: 110 W
R.M.S. Power: 55 W
Thanks!
Old 17th June 2012, 11:30 AM   #2099
Melon Head is offline Melon Head  Australia
Banned
Just ordered a tk2050 board to play around with and couple of 500W switch mode power supplies.
I am only up to page 3 in this thread but, I want to ask a question.
I am thinking of parralleling left and right channel into one channel. Is there any significant issues with doing that?
I am a class D dumb head.
Old 17th June 2012, 12:32 PM   #2100
GaloDourado is offline GaloDourado  Spain
You can not parallel outputs in these amps. You can use T3 ot T4 instead if you need more power.
New TK2050 boardHide this!Advertise here!
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 30th May 2011 11:06 PM
Any input on the new Dayton TK2050? finnbow Class D 10 2nd May 2011 11:37 PM
Parallled tk2050/st505 paolo66 Class D 1 24th November 2009 05:10 PM
New Sure electronics TK2050 T-amp xaudiox Class D 2 8th May 2009 07:50 AM
Tripath TK2050 Eccu Digital Source 0 19th April 2002 11:06 AM
Copyright ©1999-2017 diyAudio
