New TK2050 board New TK2050 board - Page 201 - diyAudio
New TK2050 board
New TK2050 board
Old 12th February 2012, 02:37 PM   #2001
TheDealer is offline TheDealer  Germany
Heyy , just posted topic No: 2000 above !!
What's my surprise gift Mr. Hifimediy, a TC2000 controller ?? Ding , ding, ding ....
Old 12th February 2012, 06:42 PM   #2002
v-bro is offline v-bro  Netherlands
v-bro's Avatar
Originally Posted by nertia View Post
Not sure this is a good idea, fully charged batteries tend to deliver more than their rated voltage. Also the bulk power cap on my board is rated 25V so 27.8V is over 10% more than its rating.
I think these boards are REALLY designed for low voltages. You might still get some good sound @ 24V with a T1 or T2 if cost/size is not an issue.
Should be no problem, as long as all parts specs are taken care of properly...
I have a TK2050 amplifier running at a voltage of 55V with no problems at all...
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
Old 13th February 2012, 02:31 AM   #2003
Nick122147 is offline Nick122147  China
There are other parts on T1-M that have a max 24V rating.
Old 13th February 2012, 11:14 AM   #2004
v-bro's Avatar
Which are?
Usually they are just some electrolytic caps, ceramic caps, and maybe a relay... Then adapt the voltage sensing, feedback and gain and you're good to go!
Old 14th February 2012, 02:06 PM   #2005
hifimediy is offline hifimediy  China
Which are?
we use 25V electrolytic cap on board.
Old 14th February 2012, 02:14 PM   #2006
Originally Posted by lovro View Post
well, you got me going around in circles now. I resoldered the rp1 the first time around.
I have attached the picture of the PR1.
Is the controller chip maybe at fault or something else?
It's strange to me too. The part seems ok from you photo.
Could you measure the wires from the resistor RP1 to the chip? I hope the trace is not broken.
What I can be sure now is that the output part is ok, so just focus on the TC2000 analog input part.
Old 14th February 2012, 02:16 PM   #2007
That's encouraging for me.
Old 14th February 2012, 06:39 PM   #2008
v-bro's Avatar
Cheers mate, but that's easy enough to fix then!
Old 14th February 2012, 11:11 PM   #2009
So far so good your T Amps just only need a bit bass treatment. It would be also encouraging me to write more on the german Tripath Test page when I (or you ?) find a Modding solution. The page is launched some weeks ago and voila there are currently T1 and T2 (with input cap mods) introduced and a non-modded poppulse. The list will be continued.
What I can tell you that T1 with battery supply sounds damn good with 8 ohm speakers. But the solid state 2 x 40 Watts Creek 4330 is a real giant killer and obviously the T1 could not hold with the bass response. On the other hand the soundstage of T1 is far better. The T2 (Battery/SMPS) with small 8 Ohm speakers sounded a bit bass-shy and lightly unbalanced. Here indeed a pair of max. 6 ohms impedance speakers are recommended. We compare with good classic solid states. In nearly future the reference equipment will completed hopefully with a 845 tube amp.
Old 15th February 2012, 07:55 AM   #2010
vmed_cha_gr is offline vmed_cha_gr  Greece
Default LINK
Hi
Can you give as a link or web page about these tests from the "german Tripath Test page " .
Vassilis
New TK2050 boardHide this!Advertise here!
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 30th May 2011 11:06 PM
Any input on the new Dayton TK2050? finnbow Class D 10 2nd May 2011 11:37 PM
Parallled tk2050/st505 paolo66 Class D 1 24th November 2009 05:10 PM
New Sure electronics TK2050 T-amp xaudiox Class D 2 8th May 2009 07:50 AM
Tripath TK2050 Eccu Digital Source 0 19th April 2002 11:06 AM
Copyright ©1999-2017 diyAudio
