New TK2050 board
New TK2050 board
Old 17th January 2012, 08:59 PM   #1991
boone is offline boone  United States
Greetings,
I have another question about hooking up my T2 special - smps300r combo. I'm
using a fused iec recp., popped the fuse out of the smps300r, to see what amperage it was, and couldn't read the markings on the fuse so went to the connexelectronics web site and to my old eyes it looks like the schematic specs a 10 amp fuse. Is that right? Seems too large to me and I don't want to fry the board if something shorts.
boone
Old 17th January 2012, 09:11 PM   #1992
alkasar is offline alkasar  France
Originally Posted by boone View Post
Greetings,
boone
10A looks too large to me to! my 300R has a 2.5A fuse.
Mains in my country is 240V. I guess you'll have to pick 5A for 110V mains.
Old 22nd January 2012, 06:05 AM   #1993
zanlation is offline zanlation  Australia
My Hifimedy T4 and SMPS500R combo is now working. I connected them up to my Paradigm Mini Monitors v6 and the amp sounds great. I don't have much to compare it too, except my Yamaha RX-V767 receiver. Thanks everyone for your advice and help. I will post pics once I have finalized the case.
Old 24th January 2012, 06:56 AM   #1994
vmed_cha_gr is offline vmed_cha_gr  Greece
Wink RECYCLED PARTS USED !
Hi
This is a HifiMeDiy T2 installed in a broken pc-dvd box, painted in glossy black , with a wooden phase plate from my sons toys. On/Off switch comes from an old mini cooper !.
Sound is amazing, i had to change the epcos input caps with Theta PPMX 2uf bypassed with mkp1837 vishay caps though to achieve better dynamics.
External power supply used is a meanwell 27v dc (wth a wima 0.47uf mkp cap sorting negative with ground).
Vassilis
Old 29th January 2012, 03:08 PM   #1995
lovro is offline lovro  Croatia
Originally Posted by hifimediy View Post
So it's ok on the output. I suggest you to re-solder the rp1 on the bottom.
well, you got me going around in circles now. I resoldered the rp1 the first time around.
I have attached the picture of the PR1.
Is the controller chip maybe at fault or something else?
Old 29th January 2012, 07:38 PM   #1996
Malefoda is offline Malefoda  France
Malefoda's Avatar
Send a message via MSN to Malefoda
Hi there,
any heat issue with the T1 or T2 STA510 @ 36V?
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, Buffalo II & NTD1, UCD400, JBL 4313B: music!
Old 31st January 2012, 11:39 AM   #1997
greententacle is offline greententacle  Finland
Default Hifimediy T1-M on 2x12V
Is it possible to run the T1-M off two 12V batteries connected in series with a 24V charger connected? The charging voltage would be 27.8V, which is too high for the amp spec, but well within the chip specs.
Old 31st January 2012, 12:56 PM   #1998
nertia is offline nertia  Scotland
Not sure this is a good idea, fully charged batteries tend to deliver more than their rated voltage. Also the bulk power cap on my board is rated 25V so 27.8V is over 10% more than its rating.
I think these boards are REALLY designed for low voltages. You might still get some good sound @ 24V with a T1 or T2 if cost/size is not an issue.
Old 31st January 2012, 05:48 PM   #1999
zman01 is online now zman01  Bangladesh
New TK2050 board
Default HifimeDIY and SMPS300R
Put together the T4 with SMPS300R - very nice results.
Thanks to forum member Kristielfur for pointing me towards this particular TK2050 based design. Friends who have heard the sound of the amp with my Alpair 12 Studio Reference Monitors really liked it.
Also thanks to user IBM5150 for helping out with the VC23 pre-amp. That one is up and running too. Nice preamp, but I like the sound of the T4 direct from source more.
-Zia
Old 12th February 2012, 02:34 PM   #2000
TheDealer is offline TheDealer  Germany
Don't know about the M but the STA510A version gives you a bit more safety room for any cases ... I never tried charging while the board was connected with but it should work.
New TK2050 boardHide this!Advertise here!
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 30th May 2011 11:06 PM
Any input on the new Dayton TK2050? finnbow Class D 10 2nd May 2011 11:37 PM
Parallled tk2050/st505 paolo66 Class D 1 24th November 2009 05:10 PM
New Sure electronics TK2050 T-amp xaudiox Class D 2 8th May 2009 07:50 AM
Tripath TK2050 Eccu Digital Source 0 19th April 2002 11:06 AM
Copyright ©1999-2017 diyAudio
