New TK2050 board
New TK2050 board
Old 22nd April 2010, 12:17 PM   #11
Nick122147 is offline Nick122147  China
Originally Posted by panda360 View Post
I have visited your shop in Taobao, but I can't find this board.
Think I got the last one of the 50 he had made. He said he'll have more ready next month.
Old 22nd April 2010, 01:28 PM   #12
panda360 is offline panda360  Hong Kong
panda360's Avatar
You are so lucky.
Old 23rd April 2010, 07:35 AM   #13
Originally Posted by sendler View Post
I like the Wurth WE-PD, XXL coils in smaller values of 6.8 or even 4.7uH for an 8 amp rating vs about 3 amps for those. The type 2 cores are the most common since they are the ones that Tripath originally recommended but even with 18guage wire on my 106mm cores they are not as transparent as the Wurths which come preasembled and ready to install for $4.
Another questions about the coils. The values you mention are much lower than the stock (11uH). It looks to me as the output filter on this board is slightly different from the sure board. It doesn't have the last 0.22uf cap after the coil. Will this affect what value of coil needed? Or could i still try with the 4.7uH coil?
Old 23rd April 2010, 11:25 AM   #14
sendler is offline sendler  United States
Default Wurth coils
You can try the lower value Wurth coils with the stock caps no problem. Then if you want, it will be easy to add the differential cap across the speaker outs as a mod. I use this filter with 3.5uH coils but 4.7uH has less out of band peaking and sounds really good.
Scott
Old 23rd April 2010, 12:33 PM   #15
hifimediy is offline hifimediy  China
Hi all, thanks for your discussion, so helpful for me to do improvement for next production.
Old 23rd April 2010, 12:36 PM   #16
I'm sorry, please give me message in Taobao if you still need it. i will reply as soon as i have.
Old 24th April 2010, 09:58 AM   #17
Thinking of changing to a stepped attenuator. The onboard one is 20K. Should I go for 20K, or can I try 50K? What difference does it make? What's best when connected to DAC Tube preamp?
Old 24th April 2010, 10:47 AM   #18
I ment to say dac, or tube preamp. (It wont let me edit my post)
Old 24th April 2010, 04:12 PM   #19
Default Passive volume control
I have done a lot of work with passive volume control. Having the pot right on the board as you do is the best way. It minimizes all of the interactions caused by it's high output impedance. I would still try 10k. 50k will sound better only with a buffer following it. A tube pre might as well bypass the pot. Switched resistors might sound a little better and offer matched steps for active cross users with multiple channels of amplification but would have to be wired on.
Scott
Old 24th April 2010, 04:45 PM   #20
Thanks sendler! So you're saying that the present solution is prefarable to adding an (higher quality) stepped pot which is wired on?
New TK2050 boardHide this!Advertise here!
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 30th May 2011 11:06 PM
Any input on the new Dayton TK2050? finnbow Class D 10 2nd May 2011 11:37 PM
Parallled tk2050/st505 paolo66 Class D 1 24th November 2009 05:10 PM
New Sure electronics TK2050 T-amp xaudiox Class D 2 8th May 2009 07:50 AM
Tripath TK2050 Eccu Digital Source 0 19th April 2002 11:06 AM
Copyright ©1999-2017 diyAudio
