New TK2050 board
New TK2050 board
Old 13th January 2012, 01:22 PM   #1971
boone is offline boone  United States
Thanks Alkasar!
boone
Old 13th January 2012, 06:06 PM   #1972
Boss187 is offline Boss187  Europe
A quick question:
For a SMPS with low current (4.5A), would a 10000uF cap be more suited?
Trying to decide between the T1 CTR and T2 sta505 10000uF.
Old 14th January 2012, 03:37 AM   #1973
hifimediy is offline hifimediy  China
Originally Posted by lovro View Post
well I have checked the rp1 and the trimmers extensively. Everything seems to work as expected.
I have reflowed all the solder joints.
I am getting the whole range (0-5v) on the trimmers.
I have also reflowed the solder joints on the R1,R2,R3,R5 resistors.
All the values of the resistors I am measuring in circuit seen the same as on the properly functioning board.
And still everything is the same, I am getting 65mv on one channel.
What should I do next?
Lovro
Hi, could you check the DC voltage from both OUT+ and OUT- to GND?
Old 14th January 2012, 04:42 AM   #1974
zanlation is offline zanlation  Australia
I have finalized my amp using the T4 and SMPS500R. When I switch it on nothing happens. The LED light on the T4 doesn't light up. I have attached a few photos below and would love some feedback on what the issue could be?
Old 14th January 2012, 10:30 AM   #1975
vmed_cha_gr is offline vmed_cha_gr  Greece
The black power input you use , does it consit of switch - fuse ?
Is the fuse there.
Do you have any output from your power supply?
Old 14th January 2012, 05:10 PM   #1976
TacticalTimbo is offline TacticalTimbo  United Kingdom
Originally Posted by TacticalTimbo View Post
Hi, noob here, probably with a question that will be annoying! Basically I don't have any experience with soldering and don't even own a iron, nor can I for the life of me work out what I would make an enclosure out of...I don't have a smelly old cigar box laying around. I'm just looking for a half decent ready to run amp based on the tk2050 IC, for use with my PC. Currently I've got a 2.1 set of Acoustic Energy Ageo M's:
http://www.amazon.co.uk/dp/B000MN96T...SIN=B000MN96T6
Would one of these be an improvement:
NEW TOPPING TP22 TP-22 & TK2050 T-AMP 2X30W & Tripath Class | eBay
I realise this is far tamer than any of the 2*100/4*100 boards being discussed hear (and possibly more money) but I will absolutely 100% mess up with a DIY job and don't want something that looks like a 5yr olds project! BTW I do also own an Onkyo TX-SR606, 8 chan AV receiver but it is absolutely huge and I've heard it's not very musical (right now its in the garage--no space). I would also need some bookshelf's as I don't have anything appropriate right now, any low cost suggestions would be great!
Is there nobody with any input on this?
Old 14th January 2012, 09:30 PM   #1977
Is the fuse there.
The black power input does consist of switch and fuse (and it is present). I don't have a meter to measure output from the power supply. This is something I will need to get if the wiring looks fine.
Old 15th January 2012, 02:08 AM   #1978
Should the neutral (blue) go to the switch before the mains?
Old 15th January 2012, 02:56 AM   #1979
The inlet switch is a DPST.
Old 15th January 2012, 06:09 AM   #1980
I strongly suggest you to find a meter and make sure the power is ok before connect to the amp board. Preparation may quicken your job
New TK2050 boardHide this!Advertise here!
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 30th May 2011 11:06 PM
Any input on the new Dayton TK2050? finnbow Class D 10 2nd May 2011 11:37 PM
Parallled tk2050/st505 paolo66 Class D 1 24th November 2009 05:10 PM
New Sure electronics TK2050 T-amp xaudiox Class D 2 8th May 2009 07:50 AM
Tripath TK2050 Eccu Digital Source 0 19th April 2002 11:06 AM
Copyright ©1999-2017 diyAudio
