New TK2050 board
New TK2050 board
Old 23rd November 2011, 03:18 PM   #1931
alkasar is offline alkasar  France
Hello, good to see your nice comments about T2-510a special edition. I enjoy this amp since spring. Its really a nice amp. I bet T3S will be even better
If you supply T2-510 at the same 27V, it does not deliver more power than regular T2. However, T2-510 has higher gain. If I remember correctly, 20V/V versus 15 for T1/T2. This gives the feeling of louder sound.
For the rest, I second your comments : it's a better chip and the amp is simply better.
You can power T2-510 up to 36V but take care of the temperature. 2x510a chips at 36V dissipate much more heat than 2x505 at 30V. The heatsink was sized for regular T2 and is undersized for T2-510a. Better put it in a large case.
Old 23rd November 2011, 05:21 PM   #1932
TheDealer is offline TheDealer  Germany
Maybe anyone's interested in my experiences. The 10.000 uF cap of T2 is in my opinion too small for torroidal and too big for smps. Just a compromise between 2 supply types. The T2 runs with a 1500 fast Panasonic much better preconditioned you use a smps. And smps is not smps. Listenning expreriences should determine finally how small the cap should be.
For T1 I would say that this board has a bit more soundstage and the bass is more punchy. But I got some trouble last times in connection with my smps. Buzz and fizzling out from smps and speakers. 2 x T1 up to now with problems. The T2 on other hand has a more tube like sweetness and no problems with my smps.
As alkasar mentioned and I hopefully understood right: With T2 you have to turn the volume more up than T1 to reach same level.
By the way: does anybody know which output voltage should be come from source for optimum gain ?
Old 26th November 2011, 11:54 AM   #1933
damarfi is offline damarfi  Croatia
Just to share with others, ordered from eBay new switching power supply s-350-48. Cheaper then Mean Well and offer free shipping. Hope will be good with Hifimediy T3s boards.
Seems that specs are slightly better then Mean Well. No fan and efficiency is higher, 86%, little bit heavier.
350W 48V 7.3A Regulated Switching Power Supply | eBay
Here is original spec from both units
http://www.meanwell.com/search/s-350/s-350-spec.pdf
http://www.chnwh.com/en/pdf/S-350W.pdf
Old 27th November 2011, 04:24 AM   #1934
hifimediy is offline hifimediy  China
1.5Vrms or about 4.2Vpp maximum for T1 through T4 and reach the maximum power on output.
Old 27th November 2011, 02:21 PM   #1935
Yet another meanwell clone
Note that most of the clones are made of poor quality or refurbished parts. Up to you to take the risk for few $ savings.
Old 27th November 2011, 08:41 PM   #1936
When I get it, will post my experience... I just don't see reason why Mean Well has to be reference in SMPS production in country of 1.4 billion people ? There are other companies as well which has good products and export around the world.
If specs are true, seems that one is better, no fan, better ripple and noise (150 mWp-p vs. 250 mWp-p), better efficiency (85% vs. 83%).
Old 27th November 2011, 10:13 PM   #1937
Tripath07 is offline Tripath07  United States
Yep, the T2 Special edition is special. I didn't change my meanwell setting from where I had it with the other amps, the T1 Alps and T2 4700. It's almost all the way up, just backed off a bit.
The T2 has the punch of the T1 and the warm sweet sound of the T2 4700. alkasar may be right about the gain, but that is just part of the sound! It also has more definition in the music, and with the notes going on in the background are clearer and more pronounced. It is just an amazing amp. I haven't plugged my T2 4700 back in since I fired up the T2 Special addition.
My wife has told me no more amps, so I would have to sneak another T2 Special in. I better wait.
I haver a better chance of getting an 36v meanwell for it, I may be able to BS her on that. lol I want to hear it with the 35v ps.
Cheers!
Old 27th November 2011, 10:14 PM   #1938
36v Meanwell
Old 30th November 2011, 12:19 AM   #1939
fb is offline fb  Australia
I got 2x T1-M recently. Very happy so far. Running at 12V, seems to be plenty of power though I'm yet to test at 'doof volumes'.
Noise is quite acceptable. Inaudible with my woofers and subs. With my 113db/W compression drivers I'm using a ~10db L-Pad and I need my ear within ~30-40cm to hear the noise.
Best part is there are no dangerous voltages involved - great for those of us who are prone to silly DIY mistakes and poor technique. And cheap!
Old 30th November 2011, 03:03 PM   #1940
Thanks ...
New TK2050 boardHide this!Advertise here!
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 31st May 2011 12:06 AM
Any input on the new Dayton TK2050? finnbow Class D 10 3rd May 2011 12:37 AM
Parallled tk2050/st505 paolo66 Class D 1 24th November 2009 06:10 PM
New Sure electronics TK2050 T-amp xaudiox Class D 2 8th May 2009 08:50 AM
Tripath TK2050 Eccu Digital Source 0 19th April 2002 12:06 PM
