New TK2050 board
New TK2050 board
Old 14th April 2011, 03:13 PM   #1501
tamphist is offline tamphist  Europe
tamphist's Avatar
Originally Posted by Commited View Post
The hiss occurs as soon as the relays click on Here's a picture of how it's all connected:
um.. connect power supplys V- and GND together. Also, use short, hi quality cables between source and amp.
Old 14th April 2011, 04:03 PM   #1502
v-bro is offline v-bro  Netherlands
v-bro's Avatar
Have you seen the schematic? This should already be the case, otherwise the amp would not work at all.
I hope you don't mean the PS GND by the way, because that should really not be connected to the amplifier anywhere....
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
Old 14th April 2011, 06:46 PM   #1503
teamacc is offline teamacc  Netherlands
Well, reports came in about the meanwell supply that connecting its gnd to its V- reduced the ripple (or something like it) by a noticeable amount.
Although, no reports about a reduction in hiss of any kind.
Old 14th April 2011, 07:52 PM   #1504
v-bro's Avatar
What ripple? It's a PWM operated power supply??? What noob wrote that?
Hiss is definitely not caused by the PS. Some distorted sounds might be, but definitely no white noise kind of hiss....
Old 14th April 2011, 10:26 PM   #1505
Well, here:
Originally Posted by ElFishi View Post
I thought I share this with you:
Mean Well S145-24 with some 10mF and a 0.39 Ohm resistor in series with floating COM, picture taken at 20mV/div and 5us/div compared to COM tied to GND, at 5mV/div and 5us/div.
And I can hear this with a B1 buffer in front of the amp.
Click the image to open in full size. Click the image to open in full size.
Old 14th April 2011, 11:32 PM   #1506
steveni70 is online now steveni70  United States
Sorry if this is a stupid question, but what does the "power down" output on the T4 do? Is it to connect a switch and put it in standby mode?
Also a more general question, where would I put a power switch, before or after the power supply? I see a lot of cool push button switches, but I can't find any rated for 120v.
Old 15th April 2011, 05:51 PM   #1507
v-bro's Avatar
Okay, an almost 50mV ripple at almost 60Khz, that's just not right! I wonder what he chose as voltage reference for the probe ground of the scope??
If that means you have to earth the output V- this is a poorly designed power supply!! Or not designed for audio....
The problem is when you earth the output you will definitely run in to ground loop problems with earthed sources..... Not very desirable.... Not really a 'solution'.....
Old 16th April 2011, 04:50 AM   #1508
Please remember that this meanwell that was tested is not the meanwell most people use.
If you have a meanwell, I hereby kindly request you to hook it up to a scope
Old 17th April 2011, 04:29 AM   #1509
progress0r is offline progress0r  United States
Guys, I finally started working on my amp, based on ver1.2 with the 510A and the Alps pot. Using the Meanwell PSU at 28V.
I've got a problem that I don't yet know how to solve. I started testing with one speaker output, and I've got a loud buzz that kind of sounds like a ground loop buzz, but isn't because the source and the amp are running off the same outlet. Also, the music is very quiet, not only relative to the buzz but overall.
The buzz appears as I plug in the input wires from the source, and is present _occasionally_ even when I use a battery-powered source like the iPod. I've reset the DC offset (it wasn't that either, that's would just result in a hiss).
When I connect the input's ground to the power supply's ground, the buzz gets quieter--currently, the input's ground is isolated from the PSU's ground and is simply connected to the "input/ground" terminal on the amp.
How do I diagnose something like this? Thanks in advance.
Old 17th April 2011, 05:23 AM   #1510
Actually, I hear the buzz with an iPod too, but it's a lot quieter.
Do you think this is a grounding issue? Does anybody know why the power terminals of the T1 amp are labeled V+ and GND (instead of V+ and V-)? I tried connecting the GND of the power terminal to the GND on the PSU and that did not work...
New TK2050 boardHide this!Advertise here!
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 30th May 2011 11:06 PM
Any input on the new Dayton TK2050? finnbow Class D 10 2nd May 2011 11:37 PM
Parallled tk2050/st505 paolo66 Class D 1 24th November 2009 05:10 PM
New Sure electronics TK2050 T-amp xaudiox Class D 2 8th May 2009 07:50 AM
Tripath TK2050 Eccu Digital Source 0 19th April 2002 11:06 AM
