New TK2050 board
New TK2050 board
Old 4th December 2010, 11:10 AM   #1131
smithie is offline smithie  United Kingdom
hi haz
if you use this cap it shouldnt hurt(then again ive been wrong before),it may change your fq response,depends what your using to drive the boards with(pre-amp).
is there a reason your drawn to this cap,i know some give it good mention but i never came to the same conclusion,although like most things with caps it just depends where its used,of course this is only my view so it means nothing,if your out to test some ruskie caps then these may also be worth a try...k73-16.
all the best
smithie
Old 4th December 2010, 05:13 PM   #1132
Nick122147 is offline Nick122147  China
Originally Posted by Haz View Post
Can anyone tell me if this capacitors are suitable to replace the 2.2 uf input cap on the arjenhelder MKI TK2050 mono block class-D amplifier's?
Or is the rated too low? What would happen if you did?
0.033uF 500V AUDIO teflon capacitors K72P-6. Lot of 8 on eBay (end time 05-Dec-10 22:59:20 GMT)
Thank you for your support
No bass. What makes you think you can exchange a 2.2uf part with a 0.033uf part?
Old 4th December 2010, 07:28 PM   #1133
there 3.3uf on my boards?
i dint notice the extra 0 there in your question
as nick says...your certainly have no bass,ive used 0.47 but as my lower reaches are covered by a plate amp i wouldnt hear any effect unless really drastic anyway
all the best
smithie
Old 5th December 2010, 07:16 PM   #1134
Haz is offline Haz  United Kingdom
It was worth asking I thought, not entirely sure what the input caps do. I just like messing with things to see what effect it will have.
Old 5th December 2010, 07:27 PM   #1135
Originally Posted by smithie View Post
hi haz
all the best
smithie
I was drawn to his cap due to another thread on this forum stating that this cap (K72P-6) and teflon capacitors in general are one of the best. Other reason are there priced very cheap!! And words like Military equipment and 0,5 grams of silver sound impressive!!
If anyone would like to throw some other brands my way that they would recommend I would be very grateful.
Thank you for you support!!
Old 5th December 2010, 10:37 PM   #1136
alkasar is offline alkasar  France
Haz, you ask to change on ajenhelder's board; This is not the appropriate thread
For an input impedance of 50K, a 0.033F cap would filter at 100Hz. Much too high and you would seriously lose bass.
If you want to try these caps as input caps, find some in the range of 2.2F to 4.7F.
Usually, people use MKP caps.
Old 6th December 2010, 12:25 AM   #1137
sorry should have started a new thread. I've got the information I needed Thank you.
Old 6th December 2010, 12:31 AM   #1138
sendler is offline sendler  United States
Default Dayton foil
Dayton foil caps are my favorite paralleled to make 3.3uf. I've tried many popular MKP film caps for signal coupling and the foil caps are a step above in transparency. Foil over teflon might be even a little better but the pricing gets ridiculous.
Scott
Old 7th December 2010, 09:32 PM   #1139
azertyman is offline azertyman
Hi
I want to make my first diy amp with the T1 board. I'll be using it to drive my old (but very nice) B&W DM2000 8ohm speakers.
I'm going to buy the following items:
- The new T1 2*100W@8ohm - ALPS
- Meanwell S-350 36V
- Case, some plugs...
Now, the website doens't say anything about speaker/DC protection, so I guess that T1 doens't have it. I've been reading about the hifimediy amps for a while and I can't seem to find alot of people implementing this protection. Do you need it? I hope someone can give me some more insight in this.
Thanks in advance
Old 7th December 2010, 11:19 PM   #1140
terralune is offline terralune  Norway
Originally Posted by azertyman View Post
Hi.
Thanks in advance
The protection you are asking about is already built in, so nothing to worry about
New TK2050 boardHide this!Advertise here!
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 30th May 2011 11:06 PM
Any input on the new Dayton TK2050? finnbow Class D 10 2nd May 2011 11:37 PM
Parallled tk2050/st505 paolo66 Class D 1 24th November 2009 05:10 PM
New Sure electronics TK2050 T-amp xaudiox Class D 2 8th May 2009 07:50 AM
Tripath TK2050 Eccu Digital Source 0 19th April 2002 11:06 AM
