| Class D Switching Power Amplifiers and Power D/A conversion |
#781 | |
Otherwise I haven't noticed any signs of EMI caused by the SMPS. I have this SMPS feeding my AMT2050 V2.0 amp and it sounds excellent! |
#782 | |
Lack of noise has more to do with the design of the smps (filtering) rather than open frame IMHO. I will try this smps with hifimediy V2 board one of these days. |
#783 | |
Also, is there any sound quality difference between the ST505 and the ST508 as used in the 2x100w and 2x80watt respectively? What voltage are the feedback resistors chosen for? Do you have to drop voltage from 30v if you run 4ohm speakers? Input appreciated, thank you
#784 |
Also, would you go for a TA3020 solution or a TK2050(TC2000)+STA517B solution if you wanted more power?
#785 | ||
Yes
#786 | |
TA3020 has good feedback. I have not yet seen a direct comparison STA517B vs TA3020. Would be interesting. |
#787 |
I read on 41hz.com forums that the sta517b chip is a little quieter and thus better.
The truepath from connexelectronics has some questionable component quality. The T3 seems better. Also, one chip seems to have a little lower thd (or just better sound) than two, but, as you might notice, its only on 80w into 8 ohms, and, as board layout is a bit different, the little difference between the chips might be not noticed. |
#788 |
Thx for your replies
![]() I am contemplating what to choose... T3 vs V2 amp vs all digital 5.1 (*hint* *hint* hifimediy ).Maybe I should check the data sheets for the ST chips. I think the T amps sound very harsh when driven above 50-60% of max power. THD and IMD rises rapidly and maybe that is what I dislike about the sound (don't know how to distinguish between the two). It would be nice not to run out of power on a 8 ohm speaker system, moderate sensitivity, if watching blu-ray movies with HD sound format (they have less dynamic range compression). |
#789 |
Hmm cant seem to find THD and IMD info on the ST chips.. anyone have them?
Similar to Tripath page 9 and forward TK2050 Datasheet pdf - Stereo 50W Amplifier Chipset - Tripath |
#790 |
I hesitate between T3 vs. V2 amplifier for my 5 speakers. For five T3 should I take 5 power supply meanwell smps ? What are the alternatives ? Is there a single power supply for five T3? My speakers Klispch is two RF-82, two RS-52 and one RC-62. In your opinion what is the best solution for these speakers ? T3 or V2 ? Specifications RF-82 FREQUENCY RESPONSE 33Hz-24KHz ± 3dB POWER HANDLING 150W RMS / 600W Peak SENSITIVITY 98dB @ 2.83V / 1m NOMINAL IMPEDANCE 8 ohms compatible HIGH FREQ CROSSOVER 1400Hz thank you for your reply. Please excuse me for my english
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board | aquapiranha | Class D | 3 | 30th May 2011 11:06 PM |
| Any input on the new Dayton TK2050? | finnbow | Class D | 10 | 2nd May 2011 11:37 PM |
| Parallled tk2050/st505 | paolo66 | Class D | 1 | 24th November 2009 05:10 PM |
| New Sure electronics TK2050 T-amp | xaudiox | Class D | 2 | 8th May 2009 07:50 AM |
| Tripath TK2050 | Eccu | Digital Source | 0 | 19th April 2002 11:06 AM |
| Page generated in 0.14282 seconds (79.17% PHP - 20.83% MySQL) with 11 queries |
