| Class D Switching Power Amplifiers and Power D/A conversion |
#681 | |
. http://cgi.ebay.com/HiEnd-24-192-DAC...44694891181043 . I bought from snow without the transformer just to hear it. You can also buy the same board from Gigaworks. I had my daughter boards upgraded to DIR9001/ CS43122 and it is running direct out through caps, It already sounds better than the AK4395 I have been using even though there is a hiss from the dac chip and I can't use the excellent sounding upsampler board because it adds a whistling noise. It has great potential though so I am going to buy another board with the transformer and with all of the other optional daughter boards to play with until I find the best final solution. I am using 12vdc in for now. It is only powered on the low voltage side of the board since I am not using the opamps. Normal input voltage is labeled as 7 to 10vac and 13v to 15v -0- 13v to 15v. There is good support on the other thread if you want to continue the discussion there. . Experience with this DIY DAC ? .
Scott Last edited by sendler; 1st September 2010 at 11:17 AM. |
#682 |
Hifimediy: Do current versions of TK2050 v.1.1B, v.2.0 and T3 (or its PS) include speaker protection against DC? Thanks.
#683 |
#684 |
Greetings,
Received my v2 kit with Meanwell 27. Connected everything and started the thing. All lights seem to be good : - green on the Meanwell with 23.8 VDC measured. - green and red lights on the v2 PCB. I have music ! But only trebble, absolutely no bass, it misses half bandwidth. Did I miss something ? For the moment it's running on my second system with small JPW speakers and an old Philips CD player. All of this is usually working fine with an aura va100 amp, everything worked ok this morning. Do you have an idea ? Thank you ! cause I'm close to the end
#685 |
Speaker polarity correct?
http://thsev.blogspot.com/ |
#686 |
Some times a faulty connection of input signal will lead to similar problem.
#687 |
Speaker polarity correct yes.
I have veryfied all the inputs from CD player to board : ok. Here is an overview on the v2 PCB : do you see anything wrong ? ![]() And then re-connected speaker + RCA cables to my old amp : everything's working fine Last edited by ptiJean; 3rd September 2010 at 06:20 AM. |
#688 |
Hi, the photo do not show up, could you post again?
#689 |
#690 |
I see you twisted the potmeter... Does not seem healthy for the board to me..
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board | aquapiranha | Class D | 3 | 30th May 2011 11:06 PM |
| Any input on the new Dayton TK2050? | finnbow | Class D | 10 | 2nd May 2011 11:37 PM |
| Parallled tk2050/st505 | paolo66 | Class D | 1 | 24th November 2009 05:10 PM |
| New Sure electronics TK2050 T-amp | xaudiox | Class D | 2 | 8th May 2009 07:50 AM |
| Tripath TK2050 | Eccu | Digital Source | 0 | 19th April 2002 11:06 AM |
| Page generated in 0.11547 seconds (79.14% PHP - 20.86% MySQL) with 11 queries |
