New TK2050 board - Page 64 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 26th August 2010, 03:56 PM   #631
Originally Posted by ptiJean View Post
Thank you.
Before buying the kits, could you please explain me why v1 is better than v2 for 8ohms ?
It uses the same components, except for input power supply, right ?
Thank you.
v2 is parallel circuit so will be a little hotter than v1, so if you don't need it for 4 ohm speaker, v1 is a little more suitable for 8ohm.
Originally Posted by Baka View Post
This is something I would also like to know, disregarding the impendance and maximum output power issues for the moment.
What is the better approach soundwise - V1.1B implementing one STA508 stereo output transistor or V2.0 with one STA505 for each channel?
I have already SURE ELECTRONICS tc2000 + tp2050 two channel board with passive cooling. I would like to have an even better implementation of these Tripath chips, if possible, and with all other proven tweaks implemented.
Baki
I think both v1 and v2 will be ok for you if don't consider the load impendance and powe supply.
Old 26th August 2010, 07:43 PM   #632
MikeHunt79's Avatar
Originally Posted by hifimediy View Post
We use T106-2 core on T3 board.
Nice, that should work well, I'm quite tempted to try one now.
Old 26th August 2010, 11:44 PM   #633
Havoc08 is offline Havoc08  Denmark
Send a message via MSN to Havoc08
So... finally come to the end of this thread. A nice little 3 hour story
Your amps look really nice hifimediy and cudos for you in-depth replies and corrections on request.
I have alot of T-amps (sure 2050, 2024 - 41hz amp32, amp9(B), amp10) and I really love the sound, especially from the well implemented ones like the 41hz amps.
I have long been dreaming of a 5 channel or 7 channel class T surround amp for my OPPO BDP-83, but should I buy 3-4 of your v2 modules or wait for an all digital solution like DDX?
I haven't quite figured out yet whether all digital is the ultimate solution (like going from VGA to DVI/HDMI). Is all digital (power dac) the pinnacle of quality compared to a nice DAC solution like the CS4397 to a 2050/3020 T-amp or can there still be issues in a ddx amp that will make it come in 2nd vs. the T-amp solution?
What do you think?
Old 27th August 2010, 09:20 AM   #634
What do you think?
For multi-channel solution, I think you'd better consider DDX system(means a new project after AMu320 2.1channel). But if you have a good DAC already, you can also consider 3~4 pcs of AMT2050 boards to use together.
Old 27th August 2010, 12:08 PM   #635
The CS DAC in the oppo is very good, also for multichannel.
Do you have any comments on this "I haven't quite figured out yet whether all digital is the ultimate solution (like going from VGA to DVI/HDMI). Is all digital (power dac) the pinnacle of quality compared to a nice DAC solution like the CS4397 to a 2050/3020 T-amp or can there still be issues in a ddx amp that will make it come in 2nd vs. the T-amp solution?"
Or comments from the rest of you peeping toms following the thread
Old 27th August 2010, 02:42 PM   #636
ptiJean is offline ptiJean  France
Just to let you know : I have ordered the v2 PCB kit, RCA, HP connectors and a Meanwell 350-27 .
I just can't wait trying all of this
Do you have advises for the chassis/box ?
I plan to try Obbligato condo, and ALPS black beauty potentiometer.
I'll work on a ventirad solution, heat is a real problem.
Thank you !
Regards from France,
Old 27th August 2010, 03:37 PM   #637
sendler is offline sendler  United States
Default box
I just tack everything down to a piece of cardboard.
Scott
Old 27th August 2010, 07:36 PM   #638
von Ah is offline von Ah  United States
von Ah's Avatar
Ever so slow progress...
A step above cardboard.
Old 27th August 2010, 07:45 PM   #639
Excellent and good job !
I would need the same kinf of box/chassis, perhaps not so high though
I advise you to take off the actuall pot, put a new one directly on the box and wire it to the PCB. Like this you can try other pots, and I promise that a good pot changes really alot ...
An ALPS blue would be better, an ALPS black beauty even more, a Dact-like, TKD, Elma, Seiden ...
Just check here :
potentiometers, switches and attenuators homepage
Do you have ebay links where to buy those chassis/boxes ?
Is it aluminium ?
Thank you,
PS: hey, I love cardboard
Old 27th August 2010, 07:49 PM   #640
Any experiences with Power Supplies or similar?
The switching frequency for the meanwell is quite close to the auible band in my oppinion so any comments on PSU choice is appreciated .
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 31st May 2011 12:06 AM
Any input on the new Dayton TK2050? finnbow Class D 10 3rd May 2011 12:37 AM
Parallled tk2050/st505 paolo66 Class D 1 24th November 2009 06:10 PM
New Sure electronics TK2050 T-amp xaudiox Class D 2 8th May 2009 08:50 AM
Tripath TK2050 Eccu Digital Source 0 19th April 2002 12:06 PM
Copyright 1999-2017 diyAudio
