New TK2050 board - Page 4 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 25th April 2010, 04:54 PM   #31
sendler is offline sendler  United States
Default I like the sound of batteries
I like the sound of batteries at 25v. It is a little better than a Meanwell at 32v but more inconvenient and no cheaper so I am sticking with the SMPS. I don't know if the batteries will hold up as well when charging in series. Many people using lead/ gel batteries listen in series and charge in parallel due to the readily available 12v chargers.
Originally Posted by Nick122147 View Post
I'm thinking of trying battery power. Would two batteries like this be ok? Can I charge them also in series with a 24V charger?
12V7AHƿ 12V7AH άʽǦ-Ա
translated specs:
Battery 12V7.0Ah/20hr
Rated Voltage: 12V
Rated Capacity (20hr): 7Ah
Dimensions: Length: 151mm Width: 66mm high: 96mm Total height: 102mm
Reference Weight: about 2.8Kg
Actual capacity of different discharge rate
20 hours rate: 7Ah
10-hour rate: 6.5Ah
5 hour rate: 5.9Ah
1 hour rate: 4.2Ah
15-minute rate: 2.9Ah
The relationship between volume and temperature (20 hour rate)
40 ℃ (104 ℉): 103%
25 ℃ (77 ℉): 100%
0 ℃ (32 ℉): 86%
-15 ℃ (5 ℉): 65%
At 25 ℃ (77 ℉) resistance when fully charged: about 22mΩ
Charging method (constant voltage)
Cycle: the maximum charge current of 1.75A
Charging voltage 14.5-15.0V/12V77 ℉ (25 ℃)
Charge temperature compensation voltage-24mV / ℃
Float: Maximum charging current 1.75A
Charging voltage 13.6-13.8V/12V77 ℉ (25 ℃)
Charge temperature compensation voltage-18mV / ℃
Apply to electronic scales, emergency lights, children's toy cars, lawn, parking locks, power systems, access control systems, uninterruptible power supplies, etc.
Scott
Old 26th April 2010, 02:44 AM   #32
Would it work using 2x12V batteries and 1 x6V to get 30V? Or 5X6V batteries? But how could I charge them?
Old 26th April 2010, 06:25 AM   #33
Call me lazy (or stupid) but I've never done DIY stuff (want to but don't know where to start & how to begin), so I just want to know if you can buy an out-of-the-box-ready amplifier with these boards?
Are these the same boards that Virtue Audio uses in their Virtue Two's?
Old 26th April 2010, 10:35 AM   #34
What about the Red Wine Audio's Signature 30?
Old 26th April 2010, 06:09 PM   #35
At 2.795,00 I'm afraid it's way too expensive.
Old 27th April 2010, 12:15 AM   #36
Default Dayton DTA-100
You might want to take a look at the new Dayton unit here, which uses the TK2050. Parts Express started selling them a month ago.
EDIT: If the link above doesn't work, try this one: http://www.parts-express.com/pe/show...number=300-383
Old 27th April 2010, 01:11 AM   #37
On topic:
How did you order your amp to NJ? And how much did it end up costing, all told?
Off Topic:
How is this typically set up? I've been wrestling with how to accomplish this very thing for my 6ch TK2050 HT power amp. I have the batteries, and all the 12V wall warts I could ever need.
Old 27th April 2010, 12:03 PM   #38
I picked up two 12V7ah Panasonic "Valve regulated lead-acid batteries" yesterday and a charger (originally for electric bikes i think). I will experince more back and forth before I make any conclution about the benefits of the batteries. I also connected the DAC to the 24V batteries, and I think that made a bigger difference. I have a 707 Super USB dac, and the sound was clearer and deeper color in a way with the batteries. But, as written, I have to experience with the meanwell and the batteries to decide how big difference I can tell from the meanwell to the batteries on the 2050.
I did also change the input caps some days ago to mcap MKP, and there might have been a small change for the better, but I felt at this point my room is making it difficult to hear this subtle differences. So I put up two blankets on the wall (looks great and the difference was much bigger than changing the cap.
The 24V charger i got for the batteries makes a awfull loud bzzz sound. The seller checked it and said it was normal. But the sound is very annoying. What causes this sound from a charger? Anything I can do to make it better? I might look for another charger if I will continue using the batteries, but havn't seen that many 24V chargers.
I havn't much experience with batteries. When should I charge them? When there is no more sound, or when the voltage drops below a certain point?
You connected them + to + and - to - for charge in paralell with 24V charger. So have to reconnect + to - for listening at 24V. I bit too much hassle for everyday use once the initual please of getting some new stuff decreases.
Old 27th April 2010, 12:23 PM   #39
Ouroboros's Avatar
The charger will probably be putting out about 27.6V so that it is safe to use as a float charger. It is worth checking the charge voltage with a meter when it is charging the batteries. I suggest you don't let the batteries drop below 22V under load as this will reduce the battery life. I am very familiar with this size of SLA battery as I use both Panasonic and Yuasa branded ones at work as standby battery suppies.
Old 27th April 2010, 12:45 PM   #40
When I connected the charger I first measured around 25V. Then it was gradually increasing. After about 2 hours I measured 30V. Is that way too much?
I only charged about 2 hours today. and I measured just above 26V after deplugging the charger.
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 30th May 2011 11:06 PM
Any input on the new Dayton TK2050? finnbow Class D 10 2nd May 2011 11:37 PM
Parallled tk2050/st505 paolo66 Class D 1 24th November 2009 05:10 PM
New Sure electronics TK2050 T-amp xaudiox Class D 2 8th May 2009 07:50 AM
Tripath TK2050 Eccu Digital Source 0 19th April 2002 11:06 AM
Copyright 1999-2017 diyAudio
