New TK2050 board - Page 202 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 15th February 2012, 08:05 AM   #2011
Originally Posted by vmed_cha_gr View Post
Hi
Can you give as a link or web page about these tests from the "german Tripath Test page " .
Vassilis
isn't it visible at the bottom (my signature) ... That would be strange or maybe your browser settings
Old 15th February 2012, 08:27 AM   #2012
i2k92 is offline i2k92  Indonesia
Originally Posted by TheDealer View Post
So far so good your T Amps just only need a bit bass treatment. It would be also encouraging me to write more on the german Tripath Test page when I (or you ?) find a Modding solution. The page is launched some weeks ago and voila there are currently T1 and T2 (with input cap mods) introduced and a non-modded poppulse. The list will be continued.
What I can tell you that T1 with battery supply sounds damn good with 8 ohm speakers. But the solid state 2 x 40 Watts Creek 4330 is a real giant killer and obviously the T1 could not hold with the bass response. On the other hand the soundstage of T1 is far better. The T2 (Battery/SMPS) with small 8 Ohm speakers sounded a bit bass-shy and lightly unbalanced. Here indeed a pair of max. 6 ohms impedance speakers are recommended. We compare with good classic solid states. In nearly future the reference equipment will completed hopefully with a 845 tube amp.
I've read somewhere on this threat about improving the bass response by replacing the inductors with Wurth. I have bought those wurth inductors, but been busy with other project, no time yet to play around with my T1. But I've replaced the input caps into PIO K75 and it can increase the bass response.
But I agree, with the price & simplicity hifimediy tripaths are hard to beat. Throw in some DIYers craziness and they will become great amps.
Old 15th February 2012, 08:50 AM   #2013
I'm behind a proxy server which has some weird behaviour.
Old 15th February 2012, 03:29 PM   #2014
that sounds very promising. Looking forward to your results with the new inductors.
Old 15th February 2012, 09:42 PM   #2015
col is offline col  Australia
col's Avatar
Does anyone know where to get a pair of speaker protection relays for a T1 V1.2?
cheers,
col.
>the relay's died?
>sorry we don't stock them.
>Hifimediy | Tripath amps
>Hifimediy Forums
>On Feb 15, 2012, at 6:58 AM, col wrote:
>[Hide Quoted Text]
> From: col <xxxxxx@xxxxxxx.xxx>
> Subject: T1 V1.2 speaker protection relays blown
> Message Body:
> Hi,
> Is it possible to buy a pair of speaker protection relays for a T1.2? Mine died a few days ago.
> regards,
> col.
> This mail is sent via contact form on Hifimediy Index of /wordpress
http://www.minirig.org.au
Old 15th February 2012, 09:53 PM   #2016
DarpMalone's Avatar
1 set Speaker protection board DIY kit | eBay
I believe these T1 boards are bridged, so you'll need one board for each channel
Old 15th February 2012, 10:04 PM   #2017
alkasar is offline alkasar  France
I believe these are hongfa JQC-3FF 24V relays
JQC-3FF-24 - SPDT 24V 5A PCB Relay
probably other vendors 24V relays would fit.
how did you blow the relays ????
Old 15th February 2012, 10:05 PM   #2018
col's Avatar
I don't want to add boards I want to replace the relays. However, those look quite similar. Maybe buying something like that would be a easier way to obtain the relays.
cheers,
col.
Old 15th February 2012, 10:13 PM   #2019
cheers,
col.
I just built this kit for another project !
The relays are a few milimeters larger than the T1/T2 stock. They won't fit the board.
Old 15th February 2012, 10:20 PM   #2020
col's Avatar
actually, maybe it's the power relay that's blown. This is the T1 V1.2 from the batch that had the faulty relays. Iv'e been running it under 24v and it has been fine up until last week.
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 30th May 2011 11:06 PM
Any input on the new Dayton TK2050? finnbow Class D 10 2nd May 2011 11:37 PM
Parallled tk2050/st505 paolo66 Class D 1 24th November 2009 05:10 PM
New Sure electronics TK2050 T-amp xaudiox Class D 2 8th May 2009 07:50 AM
Tripath TK2050 Eccu Digital Source 0 19th April 2002 11:06 AM
Copyright 1999-2017 diyAudio
