| Class D Switching Power Amplifiers and Power D/A conversion |
#181 |
#182 | |
I was too early to order. The input pins are making me feel all thumbs. That's without a soldering iron, so hopefully soon I'll see if I can slap something together. Nevertheless the board looks great! |
#183 |
I think I should have said "parallel," not "bridge." But if a single TP2050 chip can operate in either a two channel (6/8 ohm) or a paralleled one channel (4 ohm) configuration (datasheet: http://www.datasheetcatalog.org/data...h/mXyzwqtx.pdf), it would be useful to have the ability to switch between the two modes (e.g., with a dip switch).
I don't know if this feature would be practical to implement. But it would make the board more versatile, and give more people a reason to buy it. |
#184 |
Hi all, my first post here but im not new to audio (into it 30yrs) or Class T (8years,
anyways, I recieved 2 of these amps yesterday from Nick12247, i hooked one up to a Meanwell 36v supply (turned down to 31v ) in place of a stock standard Sureelectronics 2ch 2050 amp board that i had powering a pair of 8ohm bookshelf speakers,(TL 6.5s with Foster Ribbon tweets and.... WOW !! this little beast is Great ! actually i think it eats the stock Sure amp for breakfast ! super bass control, a larger soundstage and what seems like more power too ??. Had it running flatout all afternoon here (playing Trentemoeller and DeadMau5 and some Goa ) the heatsink is just cruising,thats no mean feat on this music ! i havnt tried the amp on my good dac or my on my big speakers yet ( 6 ohm VonSchwekert floorstanders ) that will be very interesting, those are currently powredd by 2 Hilly 90 /T2022 based amps,one amp on each speaker ;-) and they sound pretty dam good anyways,I am going to buy 2 more of these little beauties. Good Find ,thanksagain Nick! |
#185 |
Where to purchase the meanwell smps? Thanks.
www.hifiduino.wordpress.com |
#186 |
Scott |
#187 |
Sure Electronics' Webstore has them even cheaper.
#188 |
This isn't dangerous at all...
![]() ![]() [phone Pic] Solder-free test! PC as a source in this first test setup was too noisy, but the portable Fuze works well. I think this amp has better low level detail than my HLLY TA2020 amp. I'm using a HP brick 31VDC 3A power supply. Heat sink is kinda warm... It's great so far! I'm tickled pink!
#189 |
I've been running this board for an hour now using a 31v power supply and no audio signal. The heat dissipation (measured by fingertip) seems similar to my Sure board using a Zalman heatsink (ZM-NB47J), possibly a bit worse. I have to pull my finger away after 4-5 seconds. Even if the sound quality is better, the heat generated is pretty much the same.
#190 |
Ok, i am now listening to one of these TK2050 boards on my best speakers - ive had em 10yrs, theyr Von Schweikert VR4.5 Fullrange -6ohms 20-20- floorstanders . anyways the new amp board i installed in place of the two Hlly 90 (ta2022)amplifiers ive been using for 3 months,one hlly90 on each speaker -non bridged .
Well, anybody want to buy 2 mint Hlly 90 amps ?? lol. from first power up the new TK2050 is in another league to the hlly !! actually its alot like my Autocostruire Ta2020 boards -but with loads more power. the low bass wow !! tight tight so controled, HUGE soundstage ,detailed an sssweet ,gobloads of that Tripath mid depth and speed. i just know it will improve too with more hours use . power for the new board is from the Meanwell 36v smps ,ive now turned it up a bit from 31v to 33.8v :-) no problem so far, the heatsink is quite comfortable for me to touch for as long as i want but it is cold here -20c - its winter in australia. ive got a pair of nice Obligato caps i was going to put in -it will be so easy on this board to cap roll ,they thought of everything- but i wont yet ,the stock MKP ? input caps sound just fine. ok rave over. |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board | aquapiranha | Class D | 3 | 30th May 2011 11:06 PM |
| Any input on the new Dayton TK2050? | finnbow | Class D | 10 | 2nd May 2011 11:37 PM |
| Parallled tk2050/st505 | paolo66 | Class D | 1 | 24th November 2009 05:10 PM |
| New Sure electronics TK2050 T-amp | xaudiox | Class D | 2 | 8th May 2009 07:50 AM |
| Tripath TK2050 | Eccu | Digital Source | 0 | 19th April 2002 11:06 AM |
| Page generated in 0.13852 seconds (78.06% PHP - 21.94% MySQL) with 11 queries |
