New TK2050 board - Page 120 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 23rd December 2010, 02:19 PM   #1191
Originally Posted by von.ah View Post
What would cause the relays to rapidly click on and off in succession when powered on? MY T2 board now won't power up properly now that I've put it in a chassis. Everything worked fine months ago when I tested the board...
Hi, pls check what cause the relays to turn off, output DC or HMUTE problem first. Or try to find if there is bad solder on board, like sta505 IC etc.
Old 23rd December 2010, 02:21 PM   #1192
there is one more possible reason, the SMPS problem. take a look at the red LED (which is for power indication) and check if it's dimming when relays clicking.
Old 23rd December 2010, 02:31 PM   #1193
von Ah is offline von Ah  United States
von Ah's Avatar
Thanks. I'll check that and get back to you.
Old 23rd December 2010, 04:37 PM   #1194
ptiJean is offline ptiJean  France
As I said to Steinar few months ago I had (and still have, but rarely) the same problem with my T2 :
When switching everything on, the relays do click on and off and on, etc. again and again.
Sometimes just 2 or 3 times, sometimes for 10 min.
Sometimes everything's working fine for one week ...
I didn't find the reason.
Old 23rd December 2010, 08:31 PM   #1195
von Ah's Avatar
My output terminals were poorly fastened. That seems to have been causing the issue. DC offset was fine and I was able to adjust it down to near 0 mV. Maybe tonight I'll secure everything back inside the chassis and hopefully be done...
Whew. I hope it was all just a bonehead-invoked problem.
Old 24th December 2010, 02:29 AM   #1196
von Ah's Avatar
Well that was wishful thinking. The clicking has stopped altogether. Now I can't get the relays to engage. Green LED doesn't come on, and naturally I can't measure DC offset at the terminals.
Very discouraged.
More data points: one of the four output coils gets really hot, while the others are much cooler; the SMPS is putting out a steady 31.5 VDC; I can hear a very high frequency whine directly from the module; red LED is on, with no flickering.
I certainly don't have the skill to figure this out. I'll probably need someone else to take a look at it.
Old 24th December 2010, 06:56 AM   #1197
DarpMalone's Avatar
I've heard the high freq whine on my Sure board when an output terminal was shorted against the chassis
Old 24th December 2010, 11:50 AM   #1198
alkasar is offline alkasar  France
Very discouraged.
Sounds your relay does not engage due to amp protection.
May I suggest that you lower the SMPS to 30V (31.5 is above specs for T2), recheck the input connexions, and recheck the output terminals : no connection at all to ground/chassis here.
Also, check solder on the coils. There were reports on issues due to coils not properly soldered. Maybe damaged during transport. Check all solder
Old 24th December 2010, 05:54 PM   #1199
tamphist's Avatar
As you say it worked before you put it on a chassis.
So maybe you have accidentally shorted connections.
Check speaker and power connectors.
Old 26th December 2010, 08:14 PM   #1200
divxfr is offline divxfr  France
what's the notice of Hifimediy T1 no pot sta510A 2*100W@8ohm amplifier ?
Because I am not sound ! The relay is OK.
I do use LIN/GND/RIN cable or not ?
I am not problem with the T2 amplifier !
PLease excuse me for my english !
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 31st May 2011 12:06 AM
Any input on the new Dayton TK2050? finnbow Class D 10 3rd May 2011 12:37 AM
Parallled tk2050/st505 paolo66 Class D 1 24th November 2009 06:10 PM
New Sure electronics TK2050 T-amp xaudiox Class D 2 8th May 2009 08:50 AM
Tripath TK2050 Eccu Digital Source 0 19th April 2002 12:06 PM
Copyright 1999-2017 diyAudio
