Go Back   Home > Forums > Amplifiers > Class D
Old 9th December 2010, 02:43 PM   #1151
TCx is offline TCx  Czech Republic
Looks really cool! :-) How much power it provides and what (max.) voltage it requires?
Old 9th December 2010, 02:49 PM   #1152
Saturnus's Avatar
The STA317B is rated at 60V max and 6A max, so a total output of maximum output would be 360W total. Divide however you want, e.g. 2 x 180W into 4 Ohms at 40V.
Old 9th December 2010, 03:03 PM   #1153
Thank you for the STA317B specs. However, max. power can be limited also by other parts. The heatsink, for example, doesn't seem to be able to dissipate heat equivalent to 360W of output power.
Old 9th December 2010, 03:53 PM   #1154
Saturnus's Avatar
It wont have to since the amp is has about 90% efficiency, there'd be a maximum of 36W to dissipate. It doesn't take a large heatsink for that. With real music signal and not test signals the heatsink already on it would be more than enough (unless it's stuck inside a completely sealed box).
Old 9th December 2010, 08:01 PM   #1155
col is offline col  Australia
col's Avatar
Originally Posted by hifimediy View Post
I think this one can be called High Level because it's bigger and more HiFi.
I also put a ALPS potentiometer in because they can work together.
That looks great. is it possible to have a "clip" led?
col.
http://www.minirig.org.au
Old 9th December 2010, 11:13 PM   #1156
It's a 2nd PWM input.
I don't know it will work or not, will update soon
If I'm reading your mind correctly and this second input is the possible beginning of a new "modular" design, then I'm definitely interested.
I don't know how far along you are with the DDX amplifier project. But it might be simpler to create some DSP boards instead (2.1, 5.1, or 7.1) which can then be plugged into your existing T1/T2/T3/T4 amplifier boards for a "mix and match" solution.
Keep us posted on developments.
Old 10th December 2010, 12:08 AM   #1157
col's Avatar
Hi, pls contact Nick for relay, he has some. And it's ok for me to make some board special, like without caps as you mentioned.
Excellent,
My Caps are standard 35mm with 10mm snap-in lead pitch. Will they fit OK?
Also, I have a TA3020 based board that I power from a 35-0-35v toroidal transformer, it doesn't have speaker protection. Will your PSU board work with that?
cheers,
col.
Old 10th December 2010, 01:45 AM   #1158
col.
I'm not sure what is that, but the pot I'm using has no led.
Old 10th December 2010, 01:48 AM   #1159
T4's 2nd PWM input provide a possible to add a ex-board to accept another input channel, like digital(optical, usb, etc).
Old 10th December 2010, 01:52 AM   #1160
col's Avatar
amplifier clipping indicator light.
Power Amp Clipping Indicator
col.
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 30th May 2011 11:06 PM
Any input on the new Dayton TK2050? finnbow Class D 10 2nd May 2011 11:37 PM
Parallled tk2050/st505 paolo66 Class D 1 24th November 2009 05:10 PM
New Sure electronics TK2050 T-amp xaudiox Class D 2 8th May 2009 07:50 AM
Tripath TK2050 Eccu Digital Source 0 19th April 2002 11:06 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
