Go Back   Home > Forums > Amplifiers > Class D
Old 25th March 2010, 12:50 PM   #1
JIMMEE is offline JIMMEE  Thailand
Default class D diy or? 400Vpeak-peak
This PCB and Link
CLASS DD
Old 25th March 2010, 02:53 PM   #2
81bas is offline 81bas  Germany
It is a module from LabGruppen power amp... Used to create floating power voltage rails for slave class AB amp module (class TD)
Well, maybe I am wrong But heatsink copper fins are looking the same as by LabGruppen
Old 27th March 2010, 01:31 AM   #3
It is not module from LabGruppen (Class TD). It is module Class D from Thailand.But use heatsink copper fins.
Old 27th March 2010, 10:41 AM   #4
darkfenriz's Avatar
It looks clever but doesn't look like 6kW module, especially for reservoir capacitance and the inductor. Do you know what's the core material?
Also the layout design doesn't seem to be capable of performing clean fast switching despite heavy buffered gate drive.
However I probably don't understand all the details about the design:
- first, it is two mosfet-diode buck converters connected in parallel (BCA topology), yes?
- what is the network with two diodes and resonant tank? Any sort of soft-switching ZVT cell?
-the schematics are not readable enough for me to determine modulator/feedback topology, I guess it is some sort of clocked but am not sure about that, do you have readable versions?
Adam
Old 30th March 2010, 05:43 AM   #5
Workhorse's Avatar
Send a message via Yahoo to Workhorse
Its a copy of crown bca itech series amplifier, nothing else..........but in highly poor pcb layout.
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
Old 30th March 2010, 08:08 AM   #6
Why? output Coil dissimilar. But Crown use same coil + and -.
and this BCA PWM output
Old 30th March 2010, 09:03 AM   #7
Workhorse's Avatar
Ask the copymaster
Old 31st March 2010, 07:11 AM   #8
aandy is offline aandy  United Kingdom
core material looks like -2 from micro metals.
jimmee looks neat,most likely to be better than a crown.
the last crown i bench tested was No were near to its published ratings
Audiumsemi AS1001 - 100W peak power by 1V5 batteries? 20x more eff. than Class D tiefbassuebertr Class D 3 15th October 2009 10:57 AM
200V peak to peak @25MHz ketan Parts 1 8th June 2008 03:21 AM
clock from audiokit.ro jarthel Digital Source 5 11th April 2007 10:29 PM
Pre Outs and peak-to-peak ? CheekyMonkeyVZi Car Audio 7 12th December 2006 08:30 AM
Page generated in 0.09460 seconds (76.47% PHP - 23.53% MySQL) with 10 queries
