| Class D Switching Power Amplifiers and Power D/A conversion |
Hello
I ordered this amp off ebay(cheap starter peice) and am wondering if/how I can add a sub out connection? I know about the method of connecting a powered sub via the L/R speaker out connections. This is kind of messy so I thought adding a single rca plug would clean things up. Thanks in advance for any info T |
#2 |
If the sub has a filtered output I'd go the other way around. Source->Sub->Tripath. Then the Sats would be highpassed too. Unless you don't want that. Or get a y-cable and connect the sub parallel. Single rca would require some summing circuit, so both channels are output from the sub.
| FS: Tripath TAA4100A 4-Channel Class-T Amplifier ICs | ralphs99 | Swap Meet | 10 | 30th June 2009 06:23 PM |
| FS: Tripath EB-TA4100 4-Channel Class-T Amplifier Evaluation Board | ralphs99 | Swap Meet | 7 | 16th May 2009 09:33 AM |
| FS: Tripath TA2020 2-Channel Class-T Amplifier IC | ralphs99 | Swap Meet | 4 | 7th May 2009 11:30 PM |
| HLLY TAMP-90 90W Class T AMP AMPLIFIER Tripath TA2022 | hllyelec | Vendor's Bazaar | 2 | 19th January 2009 01:16 PM |
| Tripath 5 Channel TA3020 Amp Board with Power Supply | john65b | Swap Meet | 11 | 12th December 2007 02:55 AM |
| Page generated in 0.05844 seconds (68.84% PHP - 31.16% MySQL) with 10 queries |
