wish someone pro can help me....
i m doing a class D amplifier for subwoofer but facing problem in using the gate driver..,i hv tried to use ir2011 n hip4081 but fail. i decided to build an half bridge amp, using +-24v supply. switching frequency is 130khz. mosfet is irfb4212. any recommended gate driver n how to test it?
u mean there is no problem with tis connection? so if i short the drain of the lower side to the source of the higher side, tis circuit should b working? how to test the circuit so i can confirm it is working? if i connect anode of the oscilloscope to HO, n cathode to Vs, should it b a pulse signal tat similar to the signal of HIN? and the signal of LO and COM should b similar to the signal of LIN? is the dead time for tis circuit sufficient?
Thx a lot!!!!
Thx a lot!!!!
yes, this should work in this way
yes, something like this Make sure, that you always produce the LIN pulse first, before producing HIN pulse, since the high side driver is supplied by bootstrap capacitor (the 330nf one), which is charged during the LIN pulse...
it is needed to know the driver IC and mosfet types first. And then it is needed to know how you will produce the HIN and LIN pulses...
- Class D
- pls help...using gate driver in class D amp
