Go Back   Home > Forums > Amplifiers > Class D
Old 11th March 2010, 07:35 PM   #1
srinath is offline srinath  United States
Default 6 channel amp with 3 TA2020 based amps
If I was to make a unit that had 3 complete un changed TA2020 amps off ebay - say like this one
Lepai TA2020 Class T Amp Mini Stereo Amplifier +Adapter - eBay (item 290407411661 end time Mar-28-10 07:43:34 PDT)
Would I be able to just split the input into 3 channels and feed it to each ?
Of course power supply - I can split that. 12-18V and say 6+ amps.
But will the input signal degrade too much if I split it 3 X.
Then if I build a tube buffer like a 12AU7, would it be 1 for the whole thing in front of all the splitting, or do I have to put one per channel ?
Thanks in advance guys.
Cool.
Srinath.
Old 12th March 2010, 01:35 AM   #2
col is offline col  Australia
col's Avatar
It depends on how strong the signal source is. Would be better to have somekind of preamp with 3 outputs to boost the signal. Also, beware of ground loops!
col.
http://www.minirig.org.au
Old 12th March 2010, 02:49 AM   #3
Oh a preamp with 3 outputs. OK I can do 1 tube preamp but have 3 outputs from it ?
I guess a 3 pack of tube preamps would work ... But is there a different way.
Cool.
Srinath.
Old 12th March 2010, 03:30 AM   #4
Oh, the kenwood I have and am using now to run the 1 chip amp I got I am running it out of the headphone jack since it has volume control. Now that output can be split ?
Also how much distortion is sent out of the preamp side of the receiver ?
Thanks in advance.
Cool.
Srinath.
Old 12th March 2010, 12:38 PM   #5
Oh I had another Idea.
Could I get 3 of these -
2 x 68 Watt LM3886 + NE5532 Audio Amplifier Board Kit - eBay (item 260566539193 end time Mar-13-10 16:00:15 PST)
And that has a NE5532 pre amp circuit on the board. So I split them X3 and then the pre amp gets them stronger before the amp amplifies them.
They even have those with tube based pre amps and I being clueless get confused easy.
Cool.
Srinath.
6 channel TA2020 finished amp (setup for 12V) maurycy Swap Meet 11 1st June 2009 02:51 PM
Tripath TA2020 4 Channel Amp john65b Swap Meet 11 30th April 2009 11:42 AM
6 channel TA2020 finished amplifier PCB (setup for 12V) maurycy Swap Meet 2 27th February 2009 05:07 PM
Tripath TA2020-020 6 Channel Amp Board john65b Swap Meet 0 10th October 2005 12:20 PM
Tripath TA2020-20 6 Channel Amp Board john65b Class D 1 21st September 2005 04:43 AM
Page generated in 0.08107 seconds (70.32% PHP - 29.68% MySQL) with 10 queries
