Go Back   Home > Forums > Amplifiers > Class D
Old 9th March 2010, 10:05 PM   #1
NicMac is offline NicMac  Italy
NicMac's Avatar
Default How to bypass the Buffer stage on UcD180 modules?
Sorry if I might have asked the same question in another thread some time ago.....
I would like to make an integrated amp using the Buffalo II DAC with IVY III I/V stage (balanced output, close to zero DC offset and very low output impedance). I would like to pair this with a set of Hypex UcD180ST modules that I have coming in.
Can anybody please tell me how to bypass the coupling caps and buffer stage on the UcD180ST module? I don't need the gain, I have no or little DC offset and no real impedance issues.
Thanks,
Nic
Old 10th March 2010, 05:23 PM   #2
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
Hai, just look here:
Hybrid Hypex UCD
I removed the decoppling caps of 22uf from the UCD pcb.
They were between the opampinputbuffer and the UCD powerstage. Then i connect the input sym.+ en sym - to the new points on the PCB according the picture below.
Old 10th March 2010, 09:28 PM   #3
NicMac's Avatar
Hi Koifarm,
Thanks!!! Just the kind of info I was looking for. So the coupling caps are between the buffer and power stages and not directly on the inputs..... Do you know if this is also the way it is connected on the UcD180HG modules?
As you have done it the, mod is really simple and and pretty reversible.
I will try it. How did it work for you (sonically)?
Thanks again,
Nic
Old 11th March 2010, 10:41 AM   #4
Koifarm's Avatar
Nic, with the opampbuffer i had a little noise( hiss ) in the speaker. Without the opampbuffer there was no hiss. The sound improved in detail, staging and dynamics.
Important is that your preamp can deliver enough signal to drive the UCD.
I have no pictures of the UCD180HG, because if you bypass his opampbuffer then you can better buy the "ST" version. The biggest difference between "HG" and "ST" version is the opampbuffer you gonna bypass. Except for two powerrail capacitors.
Ronny
Old 11th March 2010, 12:48 PM   #5
NicMac's Avatar
Hi Ronny,
I have a set of the ST coming in and I will tweak these. I guess the difference of the power rail caps between the HG and ST are relatively irrelevant as I'm using a regulated supply.
I will drive the modules directly of a Buffalo II DAC that I believe to be a perfect match (balanced, low output impedance, low DC offset, 4VRMS if in dual mono, attenuation in the digital domain).
Can't wait
Nic
Old 12th March 2010, 07:55 AM   #6
Koifarm's Avatar
Buffalo Dac's are great. So the combination will be great.
Ronny
Old 24th March 2010, 10:34 PM   #7
NicMac's Avatar
What is the input impedance of a UcD180 with bypassed buffer stage? Searching the fora I find 1k8 but I think this refer to a SE connection configuration. What about balanced?
Thanks,
Nic
Old 25th March 2010, 01:08 PM   #8
Koifarm's Avatar
The impedance is the same. 1k8 for the "-" signal to earth and 1k8 for the "+" signal to earth.
Ronny
UcD180 modules placement JohanH Class D 6 21st December 2006 08:12 PM
Installing Motorized Volume Control with UCD180 Modules Spiritzly Parts 0 28th February 2006 11:45 PM
Will the UcD180 modules have enough juice for Dynaudio speakers? beppe61 Class D 4 10th December 2005 05:41 PM
Opamp + buffer, how to bypass buffer at HF for unity gain? Christer Solid State 10 29th October 2003 06:50 AM
Page generated in 0.10077 seconds (77.79% PHP - 22.21% MySQL) with 10 queries
