| Class D Switching Power Amplifiers and Power D/A conversion |
Hi, I want to design a toroidal transformer power supply for my 300W sub woofer amplifier[TAS5615]
My power supply i unregulated and the maximum input supply level is 50V for TAS5615. So what could be my transformer safer secondary voltage rating. I didn't decide my transformer type whether center tapped or bridge type and i don't know which one is best. TI recommends 16A current rating ..... Is it really required that much of power supply......?
#2 |
SINEWAVE ELECTRONICS CO.,LTD
Oh! you can't get 300W with TAS5615,THD so large,tweeter will be burned,I think you should use an regulated power supply,SMPS or liner power,I have send lots of picture on diyauduio,you can search it and research it,if you still have question I think I can give your some ideas.
#3 |
The 16A is the peak current capability which is mainly relevant if you are designing an SMPS. The average power is considerably less and a linear supply will have no problems providing the current. I would use a 300VA transformer although 150VA-500VA should be acceptable.
/U. |
#4 |
I think you can try it ,when you meet question ,upload and find idea for members on diyaudio.good luck to you!
#5 | |
#6 |
I think you can use a 300W transform out AC22-24v,Try it!
| Power Supply Design | Defbrett | Tubes / Valves | 28 | 9th October 2009 11:54 PM |
| I would like to design a power supply | Kramerguy | Power Supplies | 9 | 14th January 2009 05:50 PM |
| need help with a power supply design | lochness | Power Supplies | 1 | 31st October 2007 05:12 PM |
| Page generated in 0.08631 seconds (77.53% PHP - 22.47% MySQL) with 10 queries |
