Go Back   Home > Forums > Amplifiers > Class D
Old 24th June 2010, 03:49 AM   #11
jencelo is offline jencelo  United States
Tiff_Needle,
Any update?
Old 25th June 2010, 02:00 AM   #12
Default IcePower ASP1000 - Tweeking/Mods/Upgrades
Tiff Needle,
Looks like the binding posts on the Krell amp are Mundorfs.
For mods, I would try to get some Rubycon caps in the smaller size, and maybe Mundorfs or BHAs for the big caps. For resistors, the Shinkoas would give a little more harmonic body, and the Kiwamis more vividness. Probably best to put a couple of each in.
Not much room for PS bypass caps, but Mundorf, Jensen and Modwright caps are all very good when used as bypass caps.
The Partsconnexion in Canada is a good source of upgrade information. They sell parts and do many modifications.
Old 8th April 2011, 10:34 AM   #13
Originally Posted by Tiff_Needle View Post
Bu the way, this OPS Front end uses on JRDG PC-1 as an output of 385VDC, so does the other option that I've found, but isn't 385V above the limit setting of overvoltage protection of the ASP 1000 ?
What are your opinions on using a AC-DC FrontEnd with PFC like this one on the link below?
http://www.martekpower.com/files/pdf/PFC1000__363.pdf
or
http://www.powerstaxplc.com/products...00w-pfc-ac-dc/
Any help?
Well it's been quite a while since Ive had any time to plunge into this micro project...
I would like you opinions on the matter.
Could you be kind enough and see the PFC's data sheet and verify the compatibly between the PowerStaxPLC PFC Module and the ASP1000?
Any propositions for a voltage buffer for the input using FET's, for a balanced application?
I've been searching for the Sjøberg, Borbely, Pass circuits for a balanced configuration but so far haven't been able to find so...
I was recommended to take a look at them.
Would you recommended to add a 1:1 transformer (Lundahl 7902 input transformer) after the input buffer to improve the sub-zone (get rid of DC and HF)?
Increase the capacitor reservoir? With which capacitors? How many mF?
Tiff
Old 9th April 2011, 05:32 PM   #14
for cloning the jrdg input stage use L4 R2 config in 7902 datasheet , from R2o/p apply the "Optimum termination for best squarewave
response' the bal signal then feed into an instrumentation amp, consist of an opa2134 and 3 resistors .the opamp is supplied with +-15v ,by pass 100n ceramic smd cap.............................
Old 9th April 2011, 09:44 PM   #15
Wow!
Ok... let me digest that.
I'll send you a PM for details.
Old 4th June 2011, 02:35 PM   #16
see 501 input in attached
Old 19th June 2011, 04:06 PM   #17
Default Dc into ac
Originally Posted by mbl View Post
Is icepower 1000ASP or 500ASP accept 385V DC?
If I used AC to DC 385V PFC, is it directly plug it into icepower AC input? Any problem?
I am very curious about this also. Any advice?
Old 20th June 2011, 01:57 AM   #18
yes
Old 20th June 2011, 04:22 AM   #19
yes
Please clarify on 'yes' . 'YES', there will be a problem if I use 385V DC into the 240V AC power input into the Icepower module, or, 'YES', i can do that without issues.
i looked at the ICEpower specs, and they only specified AC.
Old 20th June 2011, 05:54 PM   #20
ddeacon is offline ddeacon  United States
Default ICEpower Parts Available
Hello All,
I have several items that might interest some participants in this thread.
1) Icepower 1000 and 500ASP modules
2) Chassis and faceplates witk XLR, RCA, IEC and trigger cutouts from 1-7 channels. They will accept 1000, 500 and 250ASP modules
3) Lundahl 7902 PCBs and transformers, assembled or separate
4) Input buffer PCBs, raises impedence to 500K ohms
5) All necessary wire harnesses and connectors to assemble the complete, operational amplifier.
Please contact me for photos and prices.
Dennis
ESP P3A Mods/Upgrades blap0220 Solid State 72 2nd February 2012 04:49 PM
Threshold Mods or Upgrades msb64 Solid State 13 26th April 2010 02:15 AM
WTB: IcePower ASP1000 - Europe Tiff_Needle Swap Meet 14 9th April 2010 09:08 PM
Sophia Electric el34 mods/upgrades jrenkin Tubes / Valves 3 14th October 2008 09:56 AM
Copyright ©1999-2013 diyAudio
