Go Back   Home > Forums > Amplifiers > Class D
Old 17th February 2010, 10:43 PM   #1
sendler is offline sendler  United States
Default Minimum gain for Tripath TK2050?
Many Class AB amps lose stability below a certain amount of gain. Is there a minimum gain for the Tripath TC2000/TK2050 chip set? I have read through the TK2050 data sheet and find only a formula for optimizing the feedback ratio according to supply voltage but no minimum gain spec. The performance characteristics show only a "typical gain" of 15V/V for 30v supply. No spec for min or max gain. The feedback ratio obviously sets the gain. I'm using 1K and 15K resistors that come in the Sure 2X100 amp which are optimal for 32V and give a gain of 16V/V which just happens to give a perfect input sensitivity for my digital source to run direct in using only a few db of digital volume control at full reference listening levels with my inefficient Usher two ways. I am going to go active with these amps and would like much less gain for the new 100db compression tweeter section than the dipole woofers will need. Can I go down as low as 1K ohms with 9K at 20V for a gain of 10V/V for instance with no stability issues?
http://www.sure-electronics.net/download/TK2050.pdf
Scott
Old 19th February 2010, 02:18 AM   #2
Default Try it
I guess I will just have to try it myself and report back.
Scott
Old 22nd December 2011, 09:32 AM   #3
Malefoda's Avatar
Send a message via MSN to Malefoda
Hi Scott,
what were the results?
Thanks,
Matthieu
Old simple TT, cheap CDP with wise mods, Class T amp at its best: music!
Old 22nd December 2011, 12:05 PM   #4
I didn't do anything with the gain in the output stage yet. It should work fine right down to the minimum allowable voltages. Power will also be reduce though. This is mainly useful for high efficiency horn drivers.
Scott
Old 22nd December 2011, 03:14 PM   #5
Malefoda's Avatar
Thanks!
Tripath amps -- TK2050 jmar Class D 24 30th September 2010 07:41 AM
minimum gain for LM1875 Leolabs Chip Amps 3 14th November 2006 01:53 AM
Aikido pre tube for Minimum Gain rick57 Tubes / Valves 13 18th May 2006 10:20 PM
Minimum gain for 2020? Nuuk Class D 7 16th November 2005 03:24 PM
Tripath TK2050 Eccu Digital Source 0 19th April 2002 11:06 AM
Page generated in 0.08867 seconds (72.25% PHP - 27.75% MySQL) with 11 queries
