| Class D Switching Power Amplifiers and Power D/A conversion |
#11 |
Hi defect9, no sound coming out either. Which has left me baffled what I have done wrong!
Okay, I might change the LEDs over tonight see if the other LED is white. I need sound!!
#12 |
you might need to post a pic of your wiring job. mine fired up proper right out of the box once I connected everything. I'm also using the switchmode powersupply, which I doubt is the issue, but, ya never know. (interesting sidenote, you can also use a computer power supply, but I wouldn't do that unless you exactly know what you doing)
one thing I did when I got the amp was poke at the inductors and make sure they weren't touching the heatsink or each other. it probably wasn't necessary, but it was one of those "it just looks better" things. also examine the board for any failed solder attempts. something else that I wonder about. you specifically mentioned the DC input. do you mean the plug input, or the green crimp block input? |
#13 |
My bad! I didn't even check the car battery. It must be faulty, it is only outputting 4.8V DC! STupid me!
I will find a replacement battery which outputs 12V DC and give it another go! Will report back soon
#14 |
| Good Experience with Arjen Helder | mfong | Class D | 6 | 10th May 2011 07:07 PM |
| ta2020 in fault mode - help for beginner | yumiyoshi | Class D | 1 | 10th February 2010 02:49 AM |
| Arjen's tube buffer for pre-amp | Josephjcole | Class D | 22 | 8th February 2010 01:18 PM |
| Input impedance of Arjen's amp? | robandjulz | Class D | 1 | 4th December 2009 01:00 PM |
| Toroids on Arjen's mk3 | studiostevus | Class D | 7 | 21st November 2009 10:42 PM |
| Page generated in 0.06759 seconds (77.42% PHP - 22.58% MySQL) with 10 queries |
