Go Back   Home > Forums > Amplifiers > Class D
Old 10th February 2010, 12:37 AM   #1
Default Kole KX1-5500D in protect mode. Shorted diode?
This car audio amp was in my car before I got my 2 AP30001D's. I was shredding CD's with the port on my box. (If you dont know what I mean, youtube it..) Anyways, a piece of the CD film managed to make it's way to the circuit board and short out something on the amp. I heard it go pop and a little bit of smoke. The Amp instantly went into protect mode.
Anyways..
I took the board out of the heatsink and desodered diodes D325 and D326. On diode check mode with the multimeter, they allow current to pass both ways... I believe the CD piece allowed a capacitor to short to the diodes.
I was wondering if there are any other components you guys think I should remove and test that might have also been affected.
FR104 Datasheet
http://www.datasheetcatalog.org/datasheet/surge/FR104.pdf
Thanks in advance for helping out! Im a noob at this.
-Mike
Old 13th February 2010, 03:14 AM   #2
anyone?
Old 13th February 2010, 01:41 PM   #3
baga is offline baga  Romania
I think that the burned components are rectifying the power supply for the driver of high side mosfets.Try to connect a power supply between vcc and vppd,12 to 15v,floating, - to vcc ,+ to vppd .Use a 100 ohm resistor for current limiting..If the amplifier is working,you can change the diodes.If the amplifier is not working you may have other damaged components,probably in the driving stage for mosfets.Please note that i am not 100% sure about what i 'm saying.
Onkyo TX-SV444 goes into protect mode morgangdfp Solid State 2 28th January 2009 12:46 PM
Orion 2500D trouble shooting- protect mode Scanlines Car Audio 5 30th July 2008 10:59 PM
Help....PPI 2360 won't come out of protect mode ??? kombos Car Audio 11 11th July 2007 01:20 AM
Kole Audio Amp Problem...HELP dozan1 Car Audio 4 14th February 2007 06:51 AM
onkyo amp txsv717 not working(protect mode) Tabatha Koger Parts 0 3rd February 2005 09:25 PM
Page generated in 0.06980 seconds (69.75% PHP - 30.25% MySQL) with 10 queries
