Class D at low volume levels
Old 19th February 2010, 09:16 PM   #41
sendler is offline sendler  United States
Default TK2050 switches at 650KHz
Originally Posted by 81bas View Post
well, how big is the sampling frequency you used? It is definitely NOT 2-3 MHZ, right?
The TK2050 in the Sure 2X100 is switching at 650KHz.
Scott
Old 20th February 2010, 04:26 PM   #42
phase_accurate is offline phase_accurate
Eva wrote:
In my circuit there is no clock, the purpose of sampling is to force a minimum pulse width and prevent bouncing or parasitic self oscillation when the feedback loop becomes open.
A minimum pulse-width can be obtained with such a circuit:
class-D amplifier PWM Verstrker SODFAs und D-Amps
But does one really call this sampling ?
Charles
Old 20th February 2010, 10:51 PM   #43
81bas is offline 81bas  Germany
It is completely different from how the sampling comparator is used in mentioned Tripath patents...
Old 20th February 2010, 11:02 PM   #44
How did you measured it? Could you please post here some switching waveforms from the prefilter-output of the TK2050?
Old 21st February 2010, 01:59 AM   #45
Default Data sheet
It's stated right there on the data sheet for the TC2000/TK2050 I linked a few posts back and also on any of the Tripath papers discussing filter design. It is also verified while sniffing the relative leakage with an AM radio of the various coil types I have been trying. 630-650Khz and some second harmonic at 1300KHz.
Scott
Old 21st February 2010, 10:52 AM   #46
I remember having read some paper by Tripath about reducing the switching frequency and als improving THD performance by introducing a lowpass pole in the feedback path. You couldn't do this with a classic fixed sampling-rate delta-sigma loop.
I asked Bruno Putzeys about how much he knew about Tripath's topology. He clearrly pointed out that it may all be found in their patents (and I must admit that I have only read a part of them) !
But here is what he wrote:
Tripath is basically a 3rd order self-oscillating loop. However, Adya Tripathi previously designed switched-capacitor chips so he built the loop using switched-capacitor integrators, clocked at 40MHz. The first pole is continuous-time though, in order to prevent aliasing of switching distortion. So, 1 continuous-time and 2 discrete time integrators. The average switching rate is not synchronous with the 40MHz clock, but the transitions are definitely sampled. The effect is to introduce a form of quantisation noise, and the rather high switching frequency of the class T chips was chosen in order to have enough room above 20kHz to shape this noise into.
Charles
Old 21st February 2010, 11:17 AM   #47
Charles
LOL! All this time we have talked about the completely different chips/chipsets, which are seem to be implemented with completely different modulation schemes
TA2020, which was pointed in the first post in this thread, even has no any point about some 'typical' switching frequency, and there is no way mentioned, how to adjust it. Whereas TK2050 datasheet says about it clearly (650 kHz, adjustable via capacitor in the feedback network)...
Now I am completely agree, that the TK2050 can be the self oscillating amp (having a lot better parameters in datasheet), whereas TA2020 not at all (switched caps stuff)...
Thanks Charles to clear it!
Class D at low volume levelsHide this!Advertise here!
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
Tuneful bass at low levels alspe Full Range 28 1st October 2008 01:30 PM
Copyright ©1999-2017 diyAudio
