| Class D Switching Power Amplifiers and Power D/A conversion |
I'm considering assembling a Class-D Audio kit. Wiring the pieces looks simple enough. I can get a cheap aluminium enclosure at the local electronics store. But I never did this before and I don't even know what tools to use to cut the needed holes in the enclosure. Could anyone point me to a beginner's guide to building an enclosure?
Also, I'd like to know what minimum size is recommended to build the 2x120 WPC kit at Class-D Audio? What do you use? Thanks a lot, and have mercy for a complete newbie! |
#2 |
For holes in thin metal, use a step drill. It won't 'walk' as you start the hole, and will cut much more cleanly than a twist drill. Ideally use a drill press, but a hand drill can work.
You might want to ask Class D about the enclosure size. They seem pretty responsive to questions.
The difference between theory and practice is that in theory there is no difference between theory and practice, but in practice there is. |
| Switching car audio enclosure to home enclosure | wattz | Subwoofers | 10 | 18th April 2010 05:51 PM |
| Whats the strangest enclosure you found to work? | Scioneer | Full Range | 0 | 20th September 2006 03:54 AM |
| Convert horn enclosure to sub enclosure | chipco3434 | Subwoofers | 5 | 22nd December 2004 03:54 PM |
| Would this work? | Saurav | Tubes / Valves | 36 | 23rd November 2003 06:49 AM |
| Page generated in 0.06657 seconds (67.80% PHP - 32.20% MySQL) with 10 queries |
