| Class D Switching Power Amplifiers and Power D/A conversion |
Hi all,
Ive just gotten hold of a Hlly T-AMP90 and was wondering if anyone had tried bridging one? Ive emailed Hlly about it aswel, as they advertise it can be done, just thought id ask if anyone had done it already? I tried searching but didnt find much. Thanks for any help
#2 |
Ive downloaded the manual now which has the schematic in, I can see im going to have to do quite a bit more research before I attempt this
#3 |
No, they can't be bridged. They can be paralled though to drive lower impedances.
#4 |
Hmm, it says in the manual "Can be modified to operated in bridged mode and get more output power" is that wrong?
#5 |
The TA2022 IC can be bridged, and a Chinese Poppulse T-amp similar to the Hlly T-amp 90 supports bridged mode if you use balanced input via XLR.
#6 |
#7 |
Ah i see, thanks for the replies guys.
I think I may have messed up a bit anyway, ive seen a couple of suggestions now that once bridged it can only power an 8ohm load, not 4ohm..is that right? Its a shame its not 2ohm stable, im currently using one channel to power a DVC 2ohm sub. |
#8 |
Well, it's 2 Ohms stable if you parallel the outputs (and not bridge them), so you could just get 2, parallel both and drive one VC with each.
#9 |
Yes, TAMP-90 support bridged out!
User can download the manual here: www.hllyelectronics.com/download/T90/BTL.doc Thanks |
#10 |
Thanks for that hllyelec, that wasnt in the file I downloaded originally, looks like a pretty simple mod
![]() Unfortunately I probably wont be doing it now if it can only handle 8ohm bridged, maybe ill get a 2nd at some point as Saturnus says, for the time being ill just use the one channel. Thanks for all the input guys! |
| HLLY amps are a ripoff. BEWARE! | Mark2727 | Class D | 34 | 7th October 2011 06:26 PM |
| Hlly TA2020 Tweaks | snusovic | Class D | 7 | 4th June 2011 03:42 PM |
| has anyone tried the HLLY M-02s from eBay? | gripracer | Multi-Way | 0 | 4th December 2009 06:01 AM |
| Hlly M-01 Wood loudspeaker | danmartin | Multi-Way | 4 | 25th August 2009 05:46 AM |
| hlly t-90 amp review | mfong | Class D | 3 | 18th August 2009 11:06 PM |
| Page generated in 0.10025 seconds (78.38% PHP - 21.62% MySQL) with 10 queries |
