diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Class D (http://www.diyaudio.com/forums/class-d/)
-   -   Memphis 2000 watt blown PS (http://www.diyaudio.com/forums/class-d/159779-memphis-2000-watt-blown-ps.html)
m4ick 23rd January 2010 06:10 PM
I have a memphis mojo 2000w amp with blown power supply. Looks like missing rubber supports caused a rectifier to crack and a power supply fet to crack and POOF! A completely burned power supply.
I did the A1266s, one was split in two. I got ~5V to the gates.
The amp has been worked on before (mismatched date codes in the ouput section) and I thought it was supposed to have IRF3205s.
When I opened it they were all IRF1010E with 22Ohm resistors. Is that the original setup in these amps? My Orion was 22ohm/IRF3205.
Copyright 1999-2017 diyAudio
