Go Back   Home > Forums > Amplifiers > Class D
Old 30th January 2010, 05:24 PM   #21
AP2 is offline AP2  Italy
hi,
I understand that can be used to test, but you lose your time, work all signals incorrect up to driver .
In theory at Bridge 2 Amp (+ /-100V) produce 2500W @ 8R.
I do not think is appropriate for first Class D amplifier.
Old 31st January 2010, 02:22 AM   #22
vogor is offline vogor  Russian Federation
vogor's Avatar
Originally Posted by AP2 View Post
hi,
If to replace on D1 on ad817 then it will be much better, what else it is possible to improve in this circuit? By my approximate calculations in bridge inclusion should be 4000W@4R.
Old 31st January 2010, 09:46 AM   #23
hi,
I have only applied the formula to the theory of 200vp out.
3 parameters are needed for accurate power Out
load, rail voltage (power supply voltage decrease under current), and Vp on load
(Rail voltage - inefficiency of power out stage)
this for continuos power. (peak power is higher, becouse probable use big capacitors on voltage) this is measured with adequate burst signal on amplifier.
your scheme is too simple to support a very fast op-amp or comparator.
new circuit must be designed, including pre-driver solutions must be good.
Old 31st January 2010, 09:53 PM   #24
vogor's Avatar
For me the main priorities of the given class it is efficiency, power, quality, by such principle I shall aspire to develop the given circuit. The prototype is conceived not for reception of very high parameters and for the first experiment, one watt on 4 ohms would suffice also. That you particularly could recommend to change in my circuit and that you mean under pre-driver solutions. Why you count not justified application of faster op-amp or comparator?
Old 1st February 2010, 04:54 AM   #25
vogor's Avatar
I wanted to tell 1KW on 4 ohms
Old 1st February 2010, 07:45 AM   #26
Bender.ru's Avatar
Hi, Vogor!
Maybe it will be better, if you start with something lighter & more simple, as you were advised early ?
Old 26th February 2010, 01:40 PM   #27
Reactance's Avatar
Hi all
This amp will work indeed, because its a circuit layout of a "irf example class-d amp application note" thats almost identical to the orignal ! i shall post the real deal on monday!
i was looking at this circuit just lastnight noticed the input stage that smelled familiar :-D
There’s nothing worse than the smell of burned output transistors!!
Old 26th February 2010, 02:06 PM   #28
yes,works...
use fast comp instead di slow opamp,You can also improve pre-drive stage.this is critical for IMD-thd.
Old 26th February 2010, 02:12 PM   #29
ok, this is IRDAMP1... just to discourage listening.
Old 26th February 2010, 09:05 PM   #30
vogor's Avatar
Question: whether If to do a bridge exit and a unipolar power supply that it will be necessary levelshifter stage?
My first class A amplifier meanman1964 Pass Labs 42 15th February 2008 07:32 AM
Class D Vs Class I (Balanced Current Amplifier) rmsaudio Class D 28 29th September 2006 07:03 AM
Selfoscillating HalfBridge 500W+500W by IR. Interested? deflorator Class D 0 10th October 2004 03:30 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 01:50 AM
Copyright ©1999-2013 diyAudio
