Selfoscillating class D amplifier - Page 12 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 4th March 2010, 03:18 PM   #111
Send a message via Yahoo to ionutzxpo
and more?... LM319 and HFE4070 OK...but there's more than that? Should I remove the C11 and C12 as well?
Old 4th March 2010, 03:27 PM   #112
thank's AP2, like this?
Old 4th March 2010, 03:32 PM   #113
AP2 is offline AP2  Italy
Banned
do not be sad.
now is ok but Vogor job on this schematic.
from my point of view, my post (power stage) may be a good starting point for
a good discrete amplifier (sure, not esoteric),but very good resolution for ..jazz.
Old 4th March 2010, 03:37 PM   #114
Thank's to VOGOR to it's his schematic
Old 4th March 2010, 03:45 PM   #115
Banned
thank at IR..for precision
but this is not important.
if I find a bit of time, I add the circuit on my "Power-Stage" for change to "Self-oscillating", and protection.
Old 5th March 2010, 06:04 AM   #116
vogor is offline vogor  Russian Federation
vogor's Avatar
To what level limit an entrance signal two diodes on an input? There is an assumption that they will not allow to receive a total power and too early begin restriction. I am going to connect the lamp preliminary cascade but it is not assured of value of sensitivity of the amplifier, a signal I take from an analogue exit of a sound card of the computer.
Old 5th March 2010, 08:59 AM   #117
81bas is offline 81bas  Germany
They do limit differential voltage between + and - inputs of opamp to about +/-0.7 Volts. But under normal operation these diodes do not limit signal at all, because the input signal will be always compensated to near zero by negative feedback at opamp inputs.
These diodes would limit the input music signal if they would be placed before R2. But they are placed after R2 so they are used only to protect opamp inputs at amp startup and shutdown, when there is nothing connected to the amp input...
With 48K NFB resistor (R3+R18) and with 2.2K input resitor the amp amplifies signal about 20 times. With 1V input signal you will get about 20V output signal. So to get the full output power with +/-65V rails you need about 2Vrms input signal.
Old 5th March 2010, 09:35 AM   #118
vogor's Avatar
I thank for an explanation, but it is possible more in detail why they will not limit an entrance signal above 0,7V if they stand after resistor R2, in what a difference?
Old 5th March 2010, 09:50 AM   #119
I have written it already: because the input signal will be always compensated to near zero by negative feedback at opamp inputs.
If in some moment at the input of amp (before R2) there will be +1V, then at amp output (after L1) there will be about -10V. And using the Ohms Law it is possible to calculate, that between R2 and R3 there will be near zero voltage at opamp inputs...
Precisely to say, the input signal will be mainly compensated via NFB, and the ripple current will be compensated via C2 and C3, but it is simplier to understand it, assuming that input signal will be compensated alone via global NFB
Old 5th March 2010, 10:33 AM   #120
vogor's Avatar
Somehow strange it turns out, if on an amplifier input will be 2V that at factor of strengthening K=20 - on an exit should be 40V but how it is possible if these limiting diodes do not allow be formed potential differences between inputs opamp more than 0,7V I can not to understand why they will not limit a signal.
Class D Vs Class I (Balanced Current Amplifier) rmsaudio Class D 29 26th January 2014 10:25 PM
My first class A amplifier meanman1964 Pass Labs 42 15th February 2008 07:32 AM
Selfoscillating HalfBridge 500W+500W by IR. Interested? deflorator Class D 0 10th October 2004 03:30 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 01:50 AM
Copyright 1999-2017 diyAudio
