Selfoscillating class D amplifier
Old 18th March 2010, 05:56 PM   #201
vogor is offline vogor  Russian Federation
vogor's Avatar
Originally Posted by 81bas View Post
It is needed to play on R4 and R2. But 35-40V threshold is OK too, I think...
Thanks!
Old 31st July 2010, 07:32 PM   #202
opor is offline opor  Thailand
Originally Posted by ionutzxpo View Post
thank's AP2, like this?
How about sound quality compare to IRS2092 based amp?
Old 31st July 2010, 07:35 PM   #203
I mean this compare to IRS2092 based amp.
Old 31st July 2010, 07:59 PM   #204
AP2 is offline AP2  Italy
Banned
it is good for start D class,to learn about the various problems.
I do not like IRS2092 amplifier and this scheme is too slow for my taste.
certain works.
regards
Old 1st August 2010, 04:56 AM   #205
stocktrader200 is offline stocktrader200  Canada
i never tried aCD 4070, but a CD4049 gives outstanding results as a comparator
I get 1.3mhz self oscillation
Old 5th June 2011, 02:29 PM   #206
This is why the startup circuit on T2 was here
Measure a voltage on C13 when the amp is 'not working' (before giving input signal). If it is less than 8-10 volts, then it is needed to reduce the resistor between Vb and +65V. Also, if the resistor is too small, then it can produce too high voltage on C13 and damage the driver. To be safe, simply put a 15V Zener diode (стабилитрон) parallel to C13.
Also, if this will not help, then it will be needed to insert delayed SD signal for IR2110.
Hi ,I have try as your suggestion . But there is 15VDC offset on out output also and amp did not start. Why?
Selfoscillating class D amplifierHide this!Advertise here!
Class D Vs Class I (Balanced Current Amplifier) rmsaudio Class D 29 26th January 2014 11:25 PM
My first class A amplifier meanman1964 Pass Labs 42 15th February 2008 08:32 AM
Selfoscillating HalfBridge 500W+500W by IR. Interested? deflorator Class D 0 10th October 2004 04:30 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 02:50 AM
