200w/8Ω smps & class d module debugging
Old 27th February 2010, 06:12 PM   #21
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
I am impressed by the TI amps, even being "feedback before the inductor" types. My only experience with a Tripath amp is the little TA2024, which is ok, but not enough power to really judge. Sometime I'll have to hear some of their more powerful types.
I have a couple of Icepower amps and some Hypex UCD amps, also extremely nice amps. UCD is probably the most ingenious amp circuit I know of, elegant and effective;
But the TI amp is rather amazing -- that they could come up with an amp design that sounds this good and is this powerful -- with all semiconductors in one chip -- is something I'd never have thought possible. Add to that the built-in SMPS design like authlxl's and suddenly power amplifiers become much more reasonable to deal with. There's really no point in using a passive crossover anymore, power amp channels and power supplies make multi-amping a no-brainer. Authlxl, I also like the +/-15 power supply outputs provided on your amp, that will come in very handy for powering the active crossovers -- how much current can that supply, by the way?
Old 28th February 2010, 03:35 AM   #22
authlxl is offline authlxl  China
SINEWAVE ELECTRONICS CO.,LTD
200w/8Ω smps & class d module debugging Send a message via MSN to authlxl
Thanks for you care,+/-15 power supply can deliver out 500mA current,+5V power supply can deliver out 500mA too,we design this parts on board aim to anyone use it easily for preamp like active crossover or DSP processor.
Old 7th June 2010, 05:06 PM   #23
Default Revise and finished bi-amp module
We have found some shortage for the previous mdule,we revise and make it as bi-amp module.
Include one 550W/4ohm/1%THD+N class D amp(300KHz-400KHz PWM frequency) and one 50W/8ohm/0.5%THD class AB amp.suit for active speaker amp,class D drive woofer and class AB drive tweeter.
We have manufactured two times,total 200pcs,no problems found,when the FLB circuit use high quality capacitor,output wave good(THD/POWER and THD/FREQUENCY) in audio range.
Class D amp can be set as 200W-550W/4ohm or 100-300W/8ohm.
Old 7th June 2010, 05:38 PM   #24
Default Wire connection diagram
Upload the wire connection diagram.
Old 8th June 2010, 03:30 AM   #25
Default Revised wire connection diagram
Resived wire connection diagram upload
200w/8Ω smps & class d module debuggingHide this!Advertise here!
L-20 200w class b amp ljm_ljm Solid State 5 3rd October 2011 03:04 PM
SMPS for class D module NewTesla Class D 40 16th May 2010 07:38 PM
200W in 8 Ohms Class D amp wanted Session Class D 5 8th October 2009 07:08 PM
Hypex UCD180ST and UCD400ST, 200W SMPS cowanrg Swap Meet 3 5th September 2007 11:12 PM
My 200W/4 class AB MOSFET amp. sparkybg Solid State 20 21st July 2005 07:39 AM
