Go Back   Home > Forums > Amplifiers > Class D
Old 17th January 2010, 08:46 PM   #1
st_eloi is offline st_eloi  Netherlands
Default Dead Channel - Charlize 2
Hello,
I recently took my charlize 2 to work and back, when I got home I removed the volume pot as I have a pre-amp. After this minor mod, one channel has stopped working. The remaining channel works fine, and sounds normal.
I don't know much about electronics, enough to hook up a psu etc. I tried testing the nearest components to the input solder points, in case I cooked them. (the inputs are the only bits I took a soldering iron to directly before the problems started) They are diodes, and with a multimeter on diode checking / continuity setting, the read short circuit both ways, though this is when they are still on the board.
NB: The continuity between RCA inputs and board inputs are all fine, with the ground of both inputs showing short circuit. Between -ve and +ve of speaker outputs shows 400 (something ohms) on both channels.
Can any one suggest a possibly problem or testing procedure to find out what is going on?
Thanks for any help,
David
Amplifer 1 channel dead .Please help Pass lover Solid State 9 14th November 2009 12:35 AM
one channel chip dead???? joka22 Chip Amps 5 8th January 2009 09:52 PM
Dead bel canto channel Sonovo Class D 2 15th January 2008 08:00 PM
Dead channel Carlp Tubes / Valves 15 1st February 2007 03:54 AM
Building 6 channel charlize amp tolse Class D 1 11th April 2006 12:15 AM
Page generated in 0.07038 seconds (69.65% PHP - 30.35% MySQL) with 10 queries
