Problems selecting the right TA2020 amp
Old 17th January 2010, 11:22 AM   #1
Pirelli is offline Pirelli  Sweden
Default Problems selecting the right TA2020 amp
After reading discussions on modifying the Topping Tp-20 on diyAudio Iíve been having problems with what to buy.
I wonder if you have any opinions on different brands.
At first I found the Muse M20 EX TA2020 and since they also sell a 60W linear power supply I thought that that was the choice.
Then I found the Hlly TAMP-20 which I thought looked much more HiFi on the PCB with all the components.
Then I read about the modified Topping.
Since I havenít found a comparison between those three, do you know if the modded Topping outperforms the Muse and Hlly? Does the latter need modifications or benefit from it as well?
Thanks in advance,
Lars-Inge
Old 17th January 2010, 11:48 AM   #2
riky is offline riky  Slovenia
i have same question
thx
riky
Old 17th January 2010, 10:26 PM   #3
rhing is offline rhing  United States
rhing's Avatar
I am ready to pull the trigger on Arjen Helder's TA2020 MkIII amp module myself. He offers a set with all the connectors, input selector switch for three inputs, LEDs, and a power switch. All you need is a nice enclosure to install everything. There are some nice extruded Aluminum project boxes available on eBay at reasonable prices.
I believe that Arjen's TA2020 MkIII board has better components like the film capacitors on the input, the large Aluminum heat sink on the Tripath chip, the larger onboard power supply electrolytic capacitor, and the micro-metal core output filter inductors. If one really wants to replace some of the components with other, more expensive components, this would be easier since there's more space on the board to do so. On the other amps mentioned, the small enclosures and limited space on the PCB would make future mods more challenging. In so many words, Arjen's amp modules are more DIY-friendly, while the other amps are fine if you don'twant to fuss with the amp too much.
Rich
Old 17th January 2010, 11:05 PM   #4
lowpoke is offline lowpoke  Australia
Rich speaks the truth, but on top of all that reports have it that they sound first rate right out of the box!
Show us what ya got at Homebuilt Hi-fi
Old 17th January 2010, 11:34 PM   #5
thx
what about plastic project boxes?
are aluminium project boxes better for SQ?
riky
Old 18th January 2010, 05:12 AM   #6
audi0 is offline audi0  Australia
Thumbs up Helder v Hlly
Just for size comparison photo shows a Helder MkIII and a Hlly (both TA2020)
BTW, the Hlly without a heat sink doesn't get hot.
The Helder is partially disassembled for upgrade, the 'Audiophiler' input caps from the Helder are now in my Topping TP20 and the tank cap is going on my Hlly
Personally I prefer metal enclosures
Steve
Old 18th January 2010, 10:54 AM   #7
Deyan is offline Deyan  Serbia
Send a message via MSN to Deyan
What about this:
Module Amplificateur - AUDIOPHONICS TA2020 V2 Module Amplificateur TRIPATH 2x20Watts
Old 18th January 2010, 11:30 AM   #8
rhing's Avatar
Originally Posted by riky View Post
thx
riky
You can use plastic or wood. These amps do not require a metal enclosure. I like Aluminum, because it can partially shield any RF noise generated by the Tripath chip's high frequency switching. The enclosure material should not affect sound quality.
I am not familiar with that amplifier, but it looks very nice. It looks like it has 1.33uF film caps at the inputs rather than the typically recommended 2uF caps. It may or may not make a difference depending how low your system can go. The power supply caps look like 330uF Panasonic FC electrolytics, which are nice. However, the size and capacitance appears to be smaller than the on-board capacitance used in Arjen's amp. This wouldn't matter with the use of their very nice power supply module:
http://www.audiophonics.fr/audiophonics-s12-module-dalimentation-hifi-tamp-12v-lt1084-p-4738.html
The thru-hole Vishay resistors and Wima caps on the amp module are a nice touch too. I would like to know if anyone on this forum has heard this amp with their power supply. With these Class T amps, the power supply has a huge influence on the sound quality.
Rich
Old 18th January 2010, 11:41 AM   #9
DreadPirate is offline DreadPirate  United States
DreadPirate's Avatar
I got a datasheet from Arjen when I placed a MKIII 2020 order, but it's file size is too large to post. If someone wants it, PM and I will send out. Has lots of close-ups.
Old 19th January 2010, 09:34 AM   #10
Thanks, so far.
I received an email answer from Arjen on the same question and he states that the MKIII PCB will have the best sound but he is biased.
He also think that Topping is better than Hlly but I disqualify him for that statement since I suspect that he's about to make a partnership with them.
One of his objects at ebay mentions: We will have our own brand fully finished amplifer with housing soon with all our PCBS also Valve pre-amplifer,please have a look at our newest version MKlll version TA2020 pcb and TA2024 PCB.
Maybe something to look forward for instead of modifying on my own.
/L-I
Problems selecting the right TA2020 ampHide this!Advertise here!
Zero T-amp TA2020 (eBay) superR Class D 10 23rd September 2010 01:31 PM
FS: T-amp TA2020 igor0203 Swap Meet 0 11th December 2009 06:27 AM
New Ta2020 Amp From Taiwan jtjames Vendor's Bazaar 17 1st March 2007 09:24 AM
Help selecting an amp FBLEAGH Solid State 1 21st September 2001 05:00 PM
Copyright ©1999-2017 diyAudio
