TPA3121 problems TPA3121 problems - diyAudio
TPA3121 problems
TPA3121 problems
Old 14th January 2010, 11:26 PM   #1
Cyberzim is offline Cyberzim  Denmark
Default TPA3121 problems
Hello,
I have attemped to make a pcb for tpa3121, but not with success.
So I would be very happy if you maybe could find some errors in my design.
My first attempt at making the board went very well, no shorts at all and everything was connected where they should. The only problem was, that the amplifier almost gave me none output. You could hear little of the music, so I measured the voltage on the pin called "High voltage power supply" and it was zero, so while it was turned on, I just made with a connection with a wire from positive supply to the pins and then it died
I have one last try, so I will post datasheets and pcblayout and cross my fingers for, that you can help me with this problem.
PCB: Imageshack.dk
Datasheets: http://focus.ti.com/lit/ds/symlink/tpa3121d2.pdf
Simon H.A.
Old 15th January 2010, 09:05 AM   #2
m-tech is offline m-tech  Serbia
Looking at picture everything is OK but, can you show us your pcb ? Some connections are very close to each other so you might have unwanted short's.
What is "High voltage power supply" ?
AVCC and PVCC should be connected to same power supply. If they are not you need to think about mute and shutdown pin because they have compliance to AVCC.
Old 15th January 2010, 09:07 AM   #3
When I get home form school, I will upload a picture of the board.
Simon H.A.
Old 15th January 2010, 10:10 AM   #4
I will also make a new board with more spacing between the connections to be more sure, that there will be no short circuits.
Old 15th January 2010, 05:50 PM   #5
Here is the picture of the board.
I have reconized that the copper gets miscolored from my fluxpen, is there a way to remove it without harming the components?
Imageshack.dk
Simon H.A.
Old 15th January 2010, 06:52 PM   #6
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
You should really try and clean the flux off the board, it's a bit of a mess.
Old 15th January 2010, 06:53 PM   #7
It's water soluble, can I just use that for cleaning the board?
Old 15th January 2010, 06:55 PM   #8
I would use distilled if possible, and get in there around the chip with a toothbrush. Make sure it's completely dry before powering it up.
No isopropyl alcohol or acetone around?
Old 15th January 2010, 07:14 PM   #9
Pano is online now Pano  United States
Pano's Avatar
TPA3121 problems
If you use alcohol, use the good stuff. It seems that all you can get in the drug store and supermarkets now in the US is 70%. Doesn't work worth a darn.
The stuff that comes in a can at the hardware store is much better. Don't know what they sell in Danmark.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 15th January 2010, 07:15 PM   #10
I have 93% at my home, so that should do it.
Simon H.A.
TPA3121 problemsHide this!Advertise here!
Problems Markz66mustang Car Audio 14 28th December 2004 06:04 AM
will this cause problems? slackerbob Multi-Way 9 29th November 2003 07:25 PM
Copyright ©1999-2017 diyAudio
