Super T Amp Clipping ! any suggestions ?
Old 4th January 2010, 08:53 PM   #1
audioaction is offline audioaction  United States
Default Super T Amp Clipping ! any suggestions ?
So I've got an old Sonic Impact "Super" T Amp I used to drive a pair of Fostex 206's with. Well I've replaced the 206's with a more floorspace friendly bookshelf setup. With the 206's volume was never a problem as they were really efficient, but now with my lesser efficient bookshelfs once I crank the volume about half up I get bad clipping/ distortion/ ugly stuff. Any suggestions on a possible remedy (different output caps perhaps?). I've seen super t mods before, but no one ever mentioned terribly bad distortion like this, may the tripath chip is biting the dust.
Old 4th January 2010, 09:08 PM   #2
Josephjcole is offline Josephjcole  United States
Josephjcole's Avatar
I'm assuming your bookshelf speakers are much less effecient than your fostex? You are probably just running out of power, and the amp is clipping. There is no good solution to this. You need a more powerful amp, more effecient speakers, or just except the lower listening levels.
Joe
Old 4th January 2010, 09:18 PM   #3
Ya the bookshelf are just a pair of sonys and are considerably less efficient, i just didnt think the t amp would struggling as bad as it is. This might be a question to be posed in two completely different forums, but how do ya'll think a pair of Fonkens would match up with a gainclone setup (i've been wanting to build both)? I like the sound of the super t amp, but the distortion is killing me. Just wondering if anything might could be done to the output stage to tweak it a bit. ?
Old 5th January 2010, 02:35 AM   #4
Pano is offline Pano  United States
Pano's Avatar
You are just overdriving the Super-T. There is only so much power you can get out of 12 volts.
That's why the little T-Amps and little tube amps need efficient speakers. They just don't have much power.
Take the Speaker Voltage Test!
Old 5th January 2010, 04:11 AM   #5
If I'm not mistaken the Fonkens are based on the fostex 127? I imagine those would go well with your T-amp. I can drive my fostex 108's with a T-amp without too much trouble, and I believe the 127's are more effecient. I don't have any first hand experience with the gainclones though so I can't comment there.
Joe
Super T Amp Clipping ! any suggestions ?Hide this!Advertise here!
Altec Lansing 9444A amp clipping problems elambert Solid State 3 7th September 2013 01:36 PM
Super Simple Valve Pre-amp Suggestions? SimonomiS Tubes / Valves 4 29th August 2009 04:04 PM
Amp clipping detector Bazukaz Solid State 8 27th February 2009 03:47 PM
Clipping and amp power supply digitaldisaster Chip Amps 3 3rd September 2007 04:53 AM
Mosfet amp goes crazy at clipping Zero Cool Solid State 22 23rd May 2007 01:38 AM
