| Class D Switching Power Amplifiers and Power D/A conversion |
I have no experience with these but just bought a 4x100w module off of Ebay to use in my home theater setup for the 2 rear, sub and center channels.
Too good to pass up and curious about that "tripath" sound I read so much about. If I like it, I may use it for my stereo L and R as well. What is the deal with the power supplies on these chips? First of all it looks like it's single sided? +24v (NOT split - and +) And unlike conventional amps it looks like it needs a regulated supply -- will a simple LM317 with a +24vdc output suffice? (I don't really listen very loud). I see elaborate switching power supplies being suggested. necessary? why? THANKS. |
#2 |
Anybody?
I'll plan on building a +24vdc supply with conventional regulation -- (an LM317) -- unless there's a reason not to. (Class D people are efficiency freaks maybe?) Even the PS should be switching? |
#3 |
My rule for switching supplies is the the switching frequency should be at least 3x the highest frequency you want to hear. So above 60khz. Then the artifacts of the switching are well outside the audio band. If you can't find an smps that does this then your better off going regulated linear.
An lm317 isn't going to have a high enough rating (1.5 amp) better to use a lm338 regulator (5 amp). |
#4 | |||
I'd advise you just get it going somehow without sinking too much money into the supply. You'll be pleasantly surprised. Or at least I have usually been. |
#5 |
Most people use the switching power supplies for three reasons:
1 simple 2 cheap 3 they sound good I imagine either of these power supplies could fit your needs: 27V DC 13A 351W Regulated Switching Power Supply_Industrial Power Adapter_Boxed Industrial Power Adapter and Chargers and Transformers_Measure Power Adapters_Sure Electronics' Webstore 36V DC 9.7A 349.2W Regulated Switching Power Supply_Industrial Power Adapter_Boxed Industrial Power Adapter and Chargers and Transformers_Measure Power Adapters_Sure Electronics' Webstore |
#6 |
In conventional power amps a regulated supply is something you DON'T WANT.
I guess with class D the rail swings are pretty tame in comparison to Class AB etc. I'll have to study up. Is there ANY advantage to regulation? Other than inherent noise reduction? (and maybe prevention of noise back into the line?) |
#7 |
#8 |
One of the big advantages of regulation is that it allows you to run near max safe voltage without ever going over. That's important in a low voltage amp. Maybe less so in a higher voltage amp where you have more margin - I.E. you don't have to run so close to max voltage to get the power you want.
Other than that, some folks like the sound of a nice regulated supply.
Take the Speaker Voltage Test! |
#9 |
If I remember correctly, an LM317 is 1 amp, LM350 is 1.5 amp
Try an old laptop power supply - usually 20VDC and 3.5 amps
"I speak Spanish to God, Italian to Women, French to Men, and German to my Horse" - Charles V |
#10 |
I retired my big linear supply when I started using the Sure 2X100 as the MeanWell smps sounds much better.
Scott |
| new Battery powered TK2050 Amps! 2 right now, I might build more later. | gripracer | Swap Meet | 18 | 31st January 2011 08:15 PM |
| Hissy Tripath amps? | MikeHunt79 | Class D | 3 | 1st May 2009 05:46 PM |
| Tripath Head Amps ? | EdT | Solid State | 1 | 13th March 2007 04:52 AM |
| Tripath TK2050 | Eccu | Digital Source | 0 | 19th April 2002 11:06 AM |
| Page generated in 0.11463 seconds (80.53% PHP - 19.47% MySQL) with 10 queries |
