new hybrid A/D amp - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 8th January 2010, 08:04 AM   #11
This idea is feasible and it isn't new either. I don't know whether there is any commercially available product using it however.
You will find quite some info on hybrid amps in AES and IEEE papers.
Nowadays pure class-d is mature enough for not needing bandaids like that. Commercial products are in most cases cost-sensitive. Something like two amps per output doesn't help in this respect.
I have seen measured performance of a new class-d prototype that rivals many conventional amplifiers. I am convinced it will cause quite some hype as soon as it is released to the market.
Charles
Old 17th March 2010, 01:11 AM   #12
This integtated amp has been reviewed in the Hi-Fi News April 2010 issue and got an ecellent verdict. According to the review the analog inputs were not nearly as good as the digital "direct" ones though. There is a brief technical explanation about the function of the amp. For my part I donīt care that much about some specifications as there is very little evidence that the amp that measures the best is the best one. Thus all new (?) ideas are very welcome. I have yet to hear a "pure" class D amp that awakes praise in my mind.
The review in pdf format is here:
http://www.absolutesounds.com/index....article_id=367
Without wonderment,no life.
Old 21st March 2010, 02:49 PM   #13
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
"Another downside is the series sense resistor directly at the output, which limits maximum possible damping factor."
and
"It may thus sound logical to "marry" both of course. But now we will get an amp whose efficiency is still lower than a class-d's efficiency and which is certainly more complicated than either kind of amps alone."
Read the review in Hi-Fi News. Firstly, the output impeadance is exceptionally low - and the sense resistor is inside the system feedback loop - no need to wory about this. Efficiency of this amp is around 90% . . . . this is as good as leading edge integrated clas s D amps (100-150W).
bonsai
https://www.ovationhifidelity.com/ and DIY here http://hifisonix.com/
Old 2nd May 2010, 08:20 AM   #14
and
Hi Bonsai,
If you are in Tokyo, the Devialet D-Premier can be heard at the mythic store Dynamic Audio HAL, on the 7th floor among other amps like Goldmund, Behold, etc.
DEVIALET&H.A.L
It was selected for their D300 system (about 3 million yens system) and is in the permanent selection.
Old 2nd May 2010, 10:53 AM   #15
AP2 is offline AP2  Italy
Banned
Hi all,
certainly is a project very professional, very nice especially the section ACD / AD but the end result can be achieved by simply by class D.
ingredients in my opinion and my experience are:
custom drivers, ultra-fast with a particular phase of the DT, this is responsible for defining the sound at high frequencies and thd to load.
this stage should have 25-30ns for "DT" and 30ns maximum propagation delay.
this stage will dissipate about 25W to the mosfet.
Interestingly, DT 25ns to 70ns dynamic realtime controlled by the output current.
after this you may think to develop the rest.
50 ns conversion time and a new scheme for the feedback (no classic) I think that listening can be very similar to class A, AB.
I have developed (for research only) a special class AB with inverse principle of class D. instead of sample, frequency of interruptions are generated proportional to the frequency signal is ingresso.result 75% efficiency, without output filter.
problem is the high cost.
Best Regards
Old 3rd May 2010, 07:54 AM   #16
Originally Posted by phase_accurate View Post
there is even an old patent by some Australians that could probably kill this one here
Any idea which Australian patent you are talking about ?
Old 4th May 2010, 02:46 PM   #17
It was a structure like figure 2 b in the following paper:
http://koasas.kaist.ac.kr/bitstream/...plications.pdf
I will have to search for it.
Charles
Old 4th May 2010, 02:54 PM   #18
Found it:
espacenet — Originaldokument
Charles
Old 9th May 2010, 07:41 PM   #19
Danish is offline Danish  United States
I think they are covering the same ground as the Garde patent. I also referenced Garde:
Method and apparatus for error ... - Google Patent Search
Old 25th December 2011, 09:17 AM   #20
I have yet to hear a Class D amplifier that sounds as good as a very good Class AB. The Devialet IMO is ridiculously overpriced and does not interest me. The Primare 132 does not sound as good as my own 120 watt Class AB amplifier and I completely disagree with the Hi-Fi mags reviews on the Primare. I found the Bel Canto S500 to be totally unlistenable. At first switch on it sounded OK but then its unrelenting bright sound made me turn it off , I had to return it to the supplier who loaned it to me. The small size & efficiency of a Class D is very good but IMO these amps are just not musical or organic enough yet. They also appear to have a frequency range restricted to 20kHz
Hybrid amp croccodillo Solid State 0 28th August 2009 02:37 PM
Hybrid Amp alpine67 Tubes / Valves 7 28th May 2008 12:53 AM
My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. Spasticteapot Multi-Way 0 30th November 2006 04:16 AM
Hybrid Amp Didier31 Solid State 21 29th June 2006 12:18 AM
What do you think about this hybrid amp? sajti Tubes / Valves 11 8th November 2004 10:33 AM
Copyright Đ1999-2017 diyAudio
