Go Back   Home > Forums > Amplifiers > Class D
Old 29th November 2009, 06:54 PM   #1
jerryo is offline jerryo  Isle of Man
Default Parallel outputs?
Is it possible to parallel the ouputs of the Tripath EB-TA2022 evaluation board to make a mono amp, without modification?
Any opinions of this board would be welcome.
Old 1st December 2009, 05:15 PM   #2
I can't recall a Tripath amp that couldn't be paralleled. Bridging is a different story.
Check out the 41Hz Amp1, the docs and forum posts on it, I think it's pretty close to the eval. board.
Did you check the datasheet?
Old 2nd December 2009, 07:22 AM   #3
Hi Kristleifur,
thanks for the reply. I asked the seller of these and he thought they could "not" be parallelled without modification.! They are on ebay and he wants about £40.00 for them, but looking at the 41hz site, for a little more money I could get an Amp5 which has the power supply on the pcb.
Thanks again
Jerryo
Parallel TDA2052 vs Parallel LM3886 for subwoofer goldyrathore Chip Amps 22 22nd November 2009 02:34 PM
paralleling computer power supply outputs: can they be connected in parallel... jarthel Parts 4 4th March 2009 11:03 PM
Balanced outputs used as inverting & Non-inverting preamplier outputs gni Solid State 4 19th September 2008 03:25 AM
Parallel LM4780/3886: leave away those 0,2Ohm between the outputs? Bassterror Chip Amps 13 11th August 2006 04:10 PM
Parallel amps & Parallel Voice coils? officeboy Multi-Way 7 26th May 2004 07:12 PM
Page generated in 0.07277 seconds (68.21% PHP - 31.79% MySQL) with 10 queries
