My first DIY amps
My first DIY amps
Old 17th November 2009, 08:55 PM   #1
Rightbrained is offline Rightbrained  United States
Default My first DIY amps
Hi all ,
I just finished 3 amps using the TDA8950 modules from cnx. I am really impressed with the sound quality and they seem to have loads of headroom with my 4 ohm diy speakers
I played them gently for the first few hours and then pounded on them for the duration of Transformers 2. They never got hot.
The case is comprised of mdf covered with oak veneer for the front and sides and .050 2024T3 aluminum for the bottom , top , and back.
The only problem I have is a high pitched pop when I power the amps up. Crisit suggested a 4.7 to 22uf cap between signal ground and the mode pin but that didnt help. Any suggestions?
Here are a few photos.
Old 18th November 2009, 08:52 PM   #2
zog666 is offline zog666  Australia
Wow nice!
I have an amp based on the Connex TDA8920 module (similar but lower power I guess?) and am very happy with it... I don't have any power on sound but there is a slight click turning the amp off.
I have found using a power use meter that the idle power consumption of the amp is negligable... and it runs very cool, so its perfect for just leaving powered on in the loungeroom 24/7.
Old 18th November 2009, 08:55 PM   #3
zog ,
I have had the same idea as well. These modules use very little power at idle.
I am hard headed though and want to be able to stop the noise.
Old 9th April 2010, 10:01 AM   #4
Kjeldsen is offline Kjeldsen  Denmark
Originally Posted by Rightbrained View Post
zog ,
I have the same problem. Did you find a solution. I haven't tried the capacitor trick yet. Cris have recommended up to 220 uF to me.
Old 9th April 2010, 07:25 PM   #5
I never did get rid of the pop and cristi stopped responding to my emails. The amps do sound good regardless.
Old 3rd May 2010, 07:10 PM   #6
Ar4 is offline Ar4  Latvia
My first DIY amps
Rightbrained, do you used double layer pcb?
My first DIY ampsHide this!Advertise here!
SMPS for diy audio amps and multi-channel diy amps (and their power supplies) tlparker Solid State 20 12th May 2015 12:23 PM
For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! opc Swap Meet 23 2nd November 2009 05:04 PM
Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest mbcouple Swap Meet 2 27th October 2008 10:27 PM
Why do some Bogan amps sound so good as guitar amps? amperex Instruments and Amps 7 22nd June 2006 11:46 AM
Has anyone compared GC amps(LM3875/3886/4780) with other DIY SS amps(Leach,ESP) ? percy Chip Amps 31 13th January 2006 01:33 AM
Copyright ©1999-2017 diyAudio
