| Class D Switching Power Amplifiers and Power D/A conversion |
#31 |
I don't know if he did the layout from scratch, but it's not only the cut free ground plane, the chip capacitors soldered directly across IC pins also count on my opinion
I tend to do high power prototypes much in the same way.It's overkill for such a small amplifier, but I'm used to see the opposite... Something intended to be class D and hi-fi should have that kind of layout anyway, parasitics always make things not work as expected
I use to feel like the small child in The Emperor's New Clothes tale |
#32 |
Of course I did!!!
Sorry, but I don't have any PCB files to share since I don't do things in a traditional way. It is highly tailored to my specific DIY PCB making methods. I will attach a PDF with a similar layout minus the DRV134 (I deleted the DRV one I think). You can use this for a single ended stereo board but will need to add the output capacitors externally. Please don't ask me what goes where or the values; I didn't make the layout to be stranger friendly.
"If you don't like funerals don't kick sand in ninja's face." |
#33 |
In the beginning I did things that way too, no schematics, component values more or less from memory, or looking at the datasheets on the fly, or calculating things on the fly as you solder them. My PCB files had no data on components too...
Now I'm designing stuff that is going to be mass produced and the amplifier in which I'm working has around 500 parts. Obviously I had to change my methods a bit... Leaving some documentation about what you do is always useful Now I even have text files with change logs and lists of ideas that I have to write as they come (to avoid the risk of forgetting something useful).Those people desperately asking for ready made files may want them for mass production too. That's what I don't like about people asking for complete design files for free... Not very DIY...
#34 |
Well, you are a pro Eva; one of the best. I am just a tinkerer, and I'm fine with that.
My component choices might not make much sense to some, but that's because I always compromise between what part is best and what components I have on hand. I don't like to buy new parts if I don't have to. Take for instance the insane amount of 1uF 100V XR7 ceramics caps I used on my boards. I have ~3000pcs of these, so why not use them if I can.
#35 | |
Thank you! |
#36 |
It works just fine. I can create the board and post a video of it?
Edit: And yes, I might be able to get the eagle files, and yes I would recommend it. Might need a bit changes in the design for better connection abilities. Regards, Simon H.A. |
#37 |
I would say;
Zip/rar/7z the eagle (and pdf) files and attach it in a reply. I and I think many others would be interested. |
#38 |
I received the pcb layout and after altering it a bit (connector size, pin distance etc) I etched the board and put it together. However, I seem to be having some 50 or 100Hz noise on the output.The amp works, but there is some humming. I have all the 100N caps and local (power) decoupling. Where should I be looking for problems? I have no >12V battery available and have not lab psu.
#39 |
Sounds like a wiring/grounding problem.
More details and pics?
#40 |
Hi, here are some pics! The PCB layout is not 100% made by me. I just altered some spacing to try the design. (As you can see I changed it not enough since I had to put components on the bottom instead of on the top.)
The input caps are 1uf. The big block caps on the right side are 680nF, one on the top, one on the bottom. The caps "parralel" to the TPA chip, right side, are the 220uF's. The resistors on the input side are 4k7 (an attempt to make the input more stable/silent). The resistors on the output side are 4k7 too, according to the datasheet. Elco's are 470uF for the HF filter and 2* 100uF local decoupling. (I had no larger value in the voltage/grid available). The center elco is 10uF from analog VCC to gnd. The input source for testing was an iPod and a CD-player with headphone output. The gain is set to high (will change that later on) The music plays ok, but when I connect the source, I have humming, with no device I have humming too. The PSU is a wall wart 15V 0.7 A PS. Please don't judge my dodgy soldering. I will use crosshair type of connections to the ground in the future. It is horrible soldering a component to a well heat-conducting surface. Last edited by superR; 11th April 2011 at 08:33 AM. |
| TPA3122 Groundings | Cyberzim | Class D | 6 | 19th September 2009 12:28 AM |
| Need clue. R speaker static when low volume, fine loud, headphones fine. . . Help? | danielwritesbac | Solid State | 4 | 30th December 2007 04:29 PM |
| Sub not working with CD (works fine with radio or iPod) | puttsthree | Car Audio | 4 | 27th December 2007 07:26 AM |
| Sony STR-DE945 - 'A' speakers suddenly quit, 'B' works fine | fridayfriday | Solid State | 11 | 8th July 2005 03:13 AM |
| Page generated in 0.12102 seconds (80.13% PHP - 19.87% MySQL) with 11 queries |
